pin 7 mod problem
Aurora, IN
Hi guys, Newb here to the board! I bought a 96 LX450 two weeks ago from a second owner and love the truck. Plan on building this truck up for mild wheeling for now as it is also a daily driver with bigger plans on down the road.
The truck has factory lockers front and rear and is full time 4wd but I wanted to try the 7 pin mod so I followed the instructions on Slee's site by pulling the thin black wire with the blue tracer. Put everything back together and went for a test drive. The only thing I am getting now is that the center diff light doesn't come on and both diff lock lights just blink. It doesn't feel like anything is locking in either.
So I pulled back in the garage, took the panel back off and made sure that the plug was pushed in all of the way and it was. Unplugged it, pushed it in again, making sure it snapped into place and went for a drive. Same problem!
Could there be a fuse blown or is the wiring different for the LX? Just can't figure out what could be wrong. I ended up just putting the wire back in the stock location for the night.
Thanks again,
Bryan
Did you also install the center difflock switch?
For testing purposes only you can unplug your emergency flasher switch and use it as a CDL switch.
Be aware that while your emergency flasher switch is unplugged, you won't have turn signals.
Slee sells em.
or the scrap yard...
You won't find one in a wrecking yard unless the vehicle was modified before it got wrecked.
I also supply them.
I just looked at where slee suggests putting the switch at, blank in the dash to the far left. I don't have a blank there I have a security light (alrm?). any other suggestions? Can I take out the security light by just unplugging it? And if I do that will the alarm still work or is it just a dummy light?
If it is a factory alarm, you might have 2 lights on 2 seperate knock outs.
One with just an LED in it, and one with a red bezel and a set of holes with the word Security under it.
That one with security is the glass brak sensor too. Keep that in mind.
I will definetly put it under the AC next to the rear heat. Thanks for the suggestion. I don't want to mess with the security.
Thanks again, this site is the most informative automotive site I have ever been on.
