I have a few big items to finish up:
1 - Locate inner axle seals
2 - Exhaust
3 - Locate hydro-assist & build brackets
I have to get the axleshafts cut, splined & installed before I can install the hydro ram. That'll enable me to find out how much steering travel I have so I can position the ram correctly. Here, I'm using 2 pieces of 1 1/2" X 1/4" wall DOM w/ an inner press fitted sleeve for alignment. The bars extend all the way out thru the spindles.
So does this mean you will be taking the pig to GSMTR???![]()
So, I doubt it'll be ready by then
You making the drive?I have a bunch of smaller items to finish or start. Still needs driveshafts, windshield installed, gotta buy another Detroit for the new 4.88's in the rear & resetup gears, will get total rewire job, hafta break down the 8274 & install new outer elec. studs & inspect inners, buy a CB/ antenna & install both, get all hydro lines, seat covers & a few more things I didn't account for. I'll need some seat/ trail time before I hit the big stuff to work out any bugsSo, I doubt it'll be ready by then
Chuck - I hope to see you at GSMTR - that way my Pig won't be lonely!
While the shafts are sent out, I'm moving over to the 40 cuz I have some frontend work that needs attention. When the shafts arrive, I reassemble the front axle & knock out those hydro ram mounts.
That's just how things went today. I wanna do over
Got my shafts in, but the short one is too shortI measured these things for 30 min & double & triple checked. :
Got my shafts in, but the short one is too shortI measured these things for 30 min & double & triple checked. I wrote them down & sent a detailed diagram for the machinework. I even confirmed the dimensions w/ one of the guys at the shop
I have the sheet at work, so I'll see what I wrote down & compare. Looks like I'm staying at work on the 40 till I get another blank sent to them & redone
<EDIT> No doubt about it, I reread the dimensions & messed it all up. Who has that Red Foreman "dumbass" pic?
I hate it when I do dumb sh*t like that! Glad to see I'm not the only one
. I'm at the stage where I have to spend ca$h to get parts. Not like I can keep on doing stuff, laborwise, or use things I already have here that's already paid for or free. Plus both tow rigs are f'n up & I gotta have those fixed first
The thread from the dead has been revived
