Pics of Green FJ40s - The BEST color. - show us what you have!!
This may be redundant but here are some pictures collected with the paint codes.
Rustic Green #621
Fashion Green T303
FJ Cruiser 6V7 2010-2011
Toyota 6H9. Hard to pin this one down. 1985 toyota color, Ditzler PPG code 45894.
Through the thread it looks anywhere from olive drab to sage green to frog green.
Nebula Green #622
where can I get a set of those missile pods for my fj40?
Here : You should have lots of usable missiles now on your new missile trailer (be sure to not cock-screw the trailer sideways any when firing-off the missiles - the trailer must remain straight in line with your rig !!). I mounted the two reusable missile pods (one to each side of the missile pod & firewood trailer) using only stainless steel fasteners, which I thought you'd appreciate. If you run-out of missiles, North Korea has got lots !! And I'm giving you a 40mm gatling gun as well (its three barrels are also stainless steel). ... Ohhh - and your rig was repainted to that of your fave color !!! ... which also helps it to camouflage it into this thread (if you find its hue of color isn't just right - it can of course be altered a bit more, prior to it getting rocket propellant soot all over it). :)
~Skydog
Here : You should have lots of usable missiles now on your new missile trailer (be sure to not cock-screw the trailer sideways any when firing-off the missiles - the trailer must remain straight in line with your rig !!). I mounted the two reusable missile pods (one to each side of the missile pod & firewood trailer) using only stainless steel fasteners, which I thought you'd appreciate. If you run-out of missiles, North Korea has got lots !! And I'm giving you a 40mm gatling gun as well (its three barrels are also stainless steel). ... Ohhh - and your rig was repainted to that of your fave color !!! ... which also helps it to camouflage it into this thread (if you find it's hue of color isn't just right - it can of course be altered a bit more, prior to it getting rocket propellant soot all over it). :)
~Skydog
My press handles 7.62 x 51mm pretty well but I don't think a 40mm die will fit. I'd also have to find primers, brass and lots of lbs. of IMR 3031.
The pods are pretty cool, 38 missiles.... that should keep me going for awhile, enough to make an impression.
What program did you use to paint my truck? Thanks!
@CHCP : I'm thinking you're going to need to get a different press. Although the 7.62 rounds might do something to a Jeep, ISIS has long been more intelligently using the far more robust Toyota 4x4 products. I doubt what you currently have will do much to the legend of Toyota. :)
... once you fire a 40mm gatling gun... you WON'T go back !! :)
Have long been using standard Photoshop.
Here's a second attempt, which is not at all a direct match by any means, but seems to be a bit closer to your ideal target :
Cheers !!
~Skydog
Cheers !!
~Skydog
My current truck configuration is different than my avatar. I have a hardtop, black front fenders and black headlight bezel (old style with Land Cruiser on it). I think this color is a little darker than Toyota 6V7. I've been thinking of keeping the black bezel and front fenders, and black fiberglass roof. I'm on the fence as to paint my hood black as well. If you can show those options in your program for me it would be great!
I'm sure the gatling gun is a blast, much better than a M203. I can still remember firing a .50 cal BMG off the fantail of AGP 1176 in 1976.
Not my rig, but green non the less. I like the look and color of this and will probably be heading in that direction with mine this fall.
I've been googling green FJ colors and found that one a few weeks ago. I think I like it. Do you know the color? I don't think it's a stock FJ color, as far as I can tell.
