Picked up used 6BT for FJZ80 swap - block questions
Sacramento
Looking to see if there are any 6BT gurus here,
Got this "rebuildable" core from facebook for $300. Guy said it came out of generator. Upon closer inspection, I see that it has 0.50 pistons, can still see cross hatching on cylinder walls and it spins very smoothly. There is a serial number on the back of the block - 48206807, not sure what that means, as well as what I think might be a date code 11 M0?
Block has surface rust but I plan on taking it to a machine to deck and clean up.
See attached.
Questions : what block do I have? If machine shops deems it need to be machined again, how much further past 0.50 can it go?
Thanks
I put your provided SN and date code into Grok and it provided the following which matches your info as a generator.
The serial number 48206807 is the official Cummins Engine Serial Number (ESN) for this 6BT-family 5.9L diesel. These are always 8-digit numeric codes (no letters) and are stamped directly into the block (often on the back or driver’s side above the oil cooler, exactly as you described). They are assigned sequentially during production, so they don’t follow a simple “year prefix” like some other brands.
Build Era from the ESN
Known reference points from Cummins records and forum cross-checks:
• Serials in the 44xxxxxx range (e.g., 44561801) were built around December 1990.
• Slightly higher ones (around 452xxxxx) are early 1990s.
Your 48206807 is quite a bit higher, which places it in the early-to-mid 2000s (likely ~2004–2011 timeframe). This is not one of the classic 1989–1998 Dodge Ram truck 6BTs (those topped out much lower in the sequence). Instead, it’s almost certainly an industrial or marine 6BT/6BTA (the “A” = aftercooled version). Cummins kept building these for generators, pumps, boats, and equipment long after they stopped supplying Dodge. The seller mentioning it came from a generator fits perfectly.
The “11 M0” Stamp
This is a separate block date/assembly code (Cummins stamps these on the block near the ESN or on the passenger side). It’s not the full build date from the dataplate. Based on how Cummins marks blocks:
• The “11” almost certainly means 2011 (or November in some formats).
• “M0” is a plant/shift/variant modifier.
Combined with the ESN progression, this points to a November 2011 (or very close to it) assembly date. Later 6BTs like this are still the same legendary inline-6 architecture—cast-iron block/head, mechanical injection (unless it’s a very late electronic one), gear-driven everything—but they often have minor factory updates for emissions or durability in industrial use.
The shop you take it to should be able to tell you how much more you can go, if they can’t, run! Hopefully good to go though.
Looking forward to seeing how this goes.
Soundproof and wrap everything.
Some generator engines have a different bellhousing pattern. Not sure about 6bT. Might want to check that its typical for adaptors you need.
