I was able to successfully remove the hardline from the back of the engine, then after dinner I am going to remove the rest of the PHH from the engine side.
I am getting my 5/8 silicon tube tomorrow. I ordered enough to do the workaround, but I thought I would give a try to re-using the hardline.
So my question is, is it easier (or even possible) to install the new PHH on the hardline side before placing it back behind the engine? I am trying to eliminate installing two hose fittings in that freakishly tiny space. I thought about "pre-fitting" the hardline end, then removing the hose before re-inserting it back into the engine- the thought being to make the final fitting a little easier.
Or perhaps I am overthinking this and should just install the bypass and be done with it. I am not a purist by any means, and if it works and its easier, then well, you know.
Let me know your thoughts.
complete with pin clamp. Looks like it has never been changed
