PHH Bypass - Dumb Question
Minneapolis MN
Getting ready for a wheeling trip next week and decided to tackle the PHH & rear heater bypass this weekend. Something has been leaking and it needed to be addressed. I found the culprit.
It turns out my heater control valve is cracked and leaking. The local dealer has one on the way for me now, but might not arrive until late in the week. ($125!!!)
Here's the dumb question: if I temporarily bypass this, is that the same as having my interior heat on full? In July? I'm pretty sure it would, but am hoping someone could help me confirm.
Just preparing for the possibility that the new part doesn't arrive in time.
Ebay Item #
111638238730
Have them next day ship it or Priority Mail
Drive Safe
You have no location listed, so hard to recommend one close.
https://forum.ih8mud.com/threads/check-your-heater-valve.285050/ and my post in that thread is #26
Heater hose to bypass and no problem for a week or so until I was back in town and had a chance to install the new replacement. Doesn't really make too much difference to internal cab temperatures even with the hose 'flowing' coolant to the heater.
cheers,
george.
I've heard that the non OEM rear heater valve may actually be better because hey open and close fully unlike the OEM one that doesn't. Anyone that can confirm that?
Is there any reason that it would be better to have a little bit of flow going through there for half the year?
No, I'm asking if there an advantage to the OEM valve which doesn't shut off all the way versus the other valves that shut 100% so the same coolant sits in your heater for six months without circulating?
I don't know. I still have the original valve. I change my coolant out at least once per year so I wouldn't be worried about it "sitting". I can't imagine it "sitting" in your lines not moving would cause any problems. If you are concerned, you could turn on your rear heat once a month for a few minutes. :meh:
That's what I mean. I think the advantage to the OEM valve is more cooling capacity because the heater core for the cabin has some coolant flow, along with the rest of the system. If it was shut off completely, I think it would reduce the cooling capacity in the summer months when the heater isn't used.
Not sure this would make a quantifiable difference. There are many guys that have eliminated their rear heater entirely so that would be the same thing. Not sure if rear heat is even an option in most countries where they don't see cold weather so I don't think it would matter any.
The OEM valve shuts off completely. I tried blowing air thru it new and No-go.
As of today, I'm one of those guys without rear heat. And I'm so glad to not have that on my worry list for upcoming trips.
I'll have to find the thread on this. I could swear that that valve doesn't close completely...
the reason i changed mine was part of the nipple on the pass side disintegrated. I mean it turned to powder and mixed with the coolant long ago. It still worked no leaks but when you blew air thru it at closed position you could hear air hissing from other side. and so much cheaper than oem
The rear heat on mine was already disconnected when I bought the car, has had no effect of my cooling system, also remembering I only run an electric fan, the OE setup back of the garage at the moment.
And the OEM valve shuts completely, this is something many forget when refilling their cooling system, the ignition must be ON then move the heater control to hot and then switch OFF the ignition to keep it there.
Stops all the "I need to hang my cruiser by the front bumper at 45 degrees from a telegraph pole fabricated from seasoned wood cut from the furthest corner of the Amazon to bleed the air out" crap you hear.
regards
Dave
