Pertronix system
Pa.
I just put this system in my 74 F40. Everything is stock on this truck.I also put in the 40,000 volt coil. I checked the timing and put in new plugs.It idles better,but I don't have as much power!!! I took it out and it just won't go like before.Even missed once. The old points were shot,and so were the plugs.I did gap the new plugs at .31.Any ideas? Thanks for the help!!
Even used new wires?
Got a Pertronix in my rig and it works well since 1999.
Yep,new wires were just put on about 6 months ago. I'm about ready to put the old points back!!
Did you doink your centrifugal advance during the Pertronix install? Put your timing light on it and see how much it advances as you rev it up.
If the plugs are really gapped at .31 and not .031, then the insulation may be breaking down or the spark cannot jump that big of a gap.
Sorry, I meant .031. The bb is about 1/2 inch below the timing mark.If I pull the vacuum line off,the bb disappears.With the vacuum line on,and I rev it up,the bb advances.
OK. Did you get the plug wires back in the right firing order?
While switching to an electonic ingition won't increase perfomance, it shouldn't run worse.
If it is pinging when you get on it, it may be a little too advanced.
The plug wires are right.I do it the old fashion way-one at a time.I'm not getting any pinging.I just don't have the power I had.I'm standing on it in second gear,and it just won't go.It was fine before. I mean for the F motor.I'm wodering if the timing is too far advanced.I'll have to play with it more tomorrow.Should the plug gap be a little wider with the new system?
I'll fool with it tomorrow.At least I have a direction.Thanks for all your help!!!
You need more advance.
This might sound dumb,but how far below the timing mark should I take the bb?
Thanks.
Tial and error: Turn it and run it and see what happens.
If you have to set the BB 10 degrees or more CCW of the pointer so that you can no longer see it in the window, I would suspect that there is something wrong with your centrifugal advance.
I think I got it!!!! Before I started fooling with the timing,I rechecked the plugs,and opened them up to .040.It's running fine now.Thanks for all your help!!!
Nah, that's just a coincidence. :D
That's my first coincidence this year!!!! I'll take it!!!! I might try to advance the timing a little before I finish.I might even be able to get it running better!!!
I had a simialr problem when I installed my pertronix. I did increase the gap, but I had to increase the advancea also. It ran ok before, but after I advanced the timing it ran excellent.
Much better after the timing advance.I could never get it to go faster than 55 by the speedometer.I had it running over 60 today.
