Recently, had a cold snap in these parts. A bit below freezing for a few days, snow & freezing rain.
Chose to drive the Cruiser, due to conditions.
Wasn't worried about the temps, as I knew I had ample antifreeze.
Drive slowly over big hill near start of my commute.
On the downhill, notice wisps of white streaming from edges of good.
Look at temp gauge and it's pegged.
I've been driving less than five minutes.
Turn it off, and pull to shoulder at bottom of hill.
Green fluid on the ground, confirming my views on antifreeze.
Get it flat-bedded home (love AAA Premier!).
Terrified the cause is corroded freeze plugs (which I'd read up on - it is an '82 FJj60, and I have no idea how good the POs were about changing fluids), because I just wasn't feeling like that level of takedown right now.
Finally got to check it yesterday.
Filled the system with water to check (still very green, so antifreeze still present), and, lo and behold, water gushes out!
But not from freeze plugs.
From the easiest dampened hose on the rig, right on top, in front.
Hose from thermostat housing to oil cooler pipe (15777C).
Ordered one. Then went and found an almost dead match at local NAPA shop.
Started her up, runs great.
Anything I should be on the lookout for?
As I said, had been running for no more than five minutes when gauge pegged. Ran fine the last time I'd driven it.
Oil shows no sign of coolant involvement (no "milkshake").
No smoke in exhaust.
Nothing proofing around the head gasket.
I'm hoping the cast-iron head & block saved the day.
