It's a 2000. No, have not replaced the grommet yet.Assuming you have a pre-03ish model that has the grommet instead of the screw in PCV. Have you replaced the grommet? Most at this age are brittle and not sealing well. When they are replaced most find that some pieces falling into the engine block which have to be removed using various grabby or suction things.
forum.ih8mud.com
Getting the readings is an important step. I’ve had codes for lean mixture on only one bank but both were reading equally lean, pointing to a vacuum leak. If only one bank is really reading lean, that points to a problem on that half of the system, like an injector or O2 sensor.Unable to see the readings. I’ve had the CEL on since May and haven’t been able to figure it out. The engine idles/runs darn near perfect. I just turned 60,000 miles
Grab a scanner from Amazon, they’re pretty inexpensive. You can either do a Bluetooth style one that links to your phone or a standalone unit.Very good points made regarding start up. Cold start takes just a hair longer than warm start. Engine cranks just a bit more but nothing concerning. Idle is great, no issues there. Unfortunately I don’t have the equipment or knowledge to monitor fuel trims.
