part # for a combination switch?
you mean the headlight control switch on the left stalk that also controls the brights and the turn signals? should be part # 84310-60700 for yours, should run around $80.
the high beams work if you pull it back and hold it, if you push it forward the headlights go out, i am guessing that since the high beams work when you pull it back than it is not the headlight relay.
i could be wrong there i do not have the factory manual for this truck. but i am assuming that it still goes through the relay to turn the high beams on rather you push or pull it.
yea jerod i might do that, i have not called cdan yet, but went to check that part # and it is for the first gens, the second gens part # i think 84310-35510 and toyota diy has a price of over $300
