Parking brake cable removal help
Springfield, OR
78 FJ40- Attempting to remove the parking brake cable from the back plate off the donor transfer case I picked up. If I recall correctly, there is a small C clip that holds the interior portion inside. The one I have does not have a C clip but will still not pull out. It appears that the outer portion of the tube might have suffered a little damage, but the entire assembly is rotating inside just fine, so I’m trying to figure out where to go from here. Any help would be greatly appreciated.
https://i.imgur.com/AL6PvvZ.jpg
https://i.imgur.com/uMw6myP.jpg
I just removed the parking brake cable from the '78 FJ55 transfer case that I'm selling, should be the same as yours. After removing the c-clip I tapped on the end of the tube from inside the backing plate and it came right out. I believe it's pretty much a snug fit, but not so tight it can't be easily driven out. I think I used a screwdriver blade with a hammer.
It looks like the tube that should be connected to that crimped end of the sheathing has separated. If the outside part of the housing shaft that it slips inside is as out-of-round as it looks it may be a bear to get out of there without cutting the cable and pulling it the other way. Here's a picture of what that year cable looks like new (still available) Mid 70's parking brake cable length question
Well, I just ended up putting it in the vice and grabbing the exterior collar with some vice grips after soaking it with brake clean. Took a little force, but it is now out. Now I’m trying to figure out how to replace the C clip when I swap it into the new brake.
