Parking Brake adjustment
New cable. Mines the same way :(
Or, you can adjust the parking brake shoes on the rear disk. It takes a long screwdriver to reach the adjustment nut.
No need to buy a new cable.
Just recently done both our 80's parking brake, no new cable needed. Stick the rear on axle stands, remove the wheels and calipers. Release the parking brake and loose the adjustment nut at the lever most of the way off. Pull each drum off to check you have some brake material left, change the shoes if not. Put the drums back on, put 3 wheel nuts back on to hold the drum on tight. Tighten up the adjuster through the little hole in the bottom of the drum till the drum won't turn then back off a few clicks till it turns without drag. Do that both sides. Back at the lever, take up the slack in the cable until you get a good pull. Don't go too far or the shoes will bind, double check the drums still turn. Put it back together and it should be ok.
There is a old mechanic here that said you have 3 clicks on your e-brake lever that can hold the Cruiser .. just to know if your e-brake it's enought tight.
