I've got a 1970 fj40 with a SBC 350. Last weekend I toasted a couple of wires due to a faulty toggle switch while I was installing a line lock. The smoked wires were the "BY" ignition coil wire and a "BR" Alternator wire. I opened the harness up and traced each wire making sure that no other wires had gotten hot and that no wires were exposed. I then replaced the wires that had gotten hot. I also soldiered all connections that were just using splice clips, or any other type of crimp connection that might fail and wasnt waterproof.
After I was done the motor fired right up and everything worked with no problems, I thought I was done..ha ha. That was last weekend.
Yesterday I went to fire her up and there was nothing. I checked the voltage on the Bat and it was drained down to 1 volt. Obvious to me that I Fooked up somwhere. I charged the Battery (that im sure im going have to replace due to the drastic current drain) and checked the voltage with the cables hooked up (and all accs. and everything else turned off) and I was loosing about 1 volt every 5 minutes. I disconnected the cables and left it overnight to make sure the battery could still hold a charge and it did. I then disconnected and ran a new ground to the line lock and still had the drain. I disabled the line lock and the drain still continued.
I went out right now to start pulling fuses to see if I could find the draw and sure enough, now there's no voltage drain. Painless harness will be installed next month but the Rubithon is to close for me to start that project..
Any ideas on what might of caused this, I know if I don't find the problem its gonna haunt me in the near future...........thanks for any info
