I’ve had a parasitic drain on my battery for probably 5 years now. I killed a Optima battery in less than two years and it looks like my Sears Platinum is heading down the same path, although it has a far better warranty.
My Land Cruiser will sometimes sit for weeks without being driven. I got tired of having a dead battery every time I wanted to use it so I installed a dual battery system. Well, this wasn’t the only reason for the dual battery, but it solved the need to get a jump. I’m running all the accessories off the main battery, a Sears Platinum 65 that is rated at 75 Amp Hrs. The second battery is a Costco group 35 and does nothing but supply power if the main dies. I use a Blue Sea 9112 automatic charging relay.
Last summer I installed a Datel voltmeter using the Gamiviti dash bezel so I could monitor both batteries during a two week camping trip. This meter shows that I’m getting about 14V to the batteries during normal driving. Voltage normally starts about 14.5 then falls to about 14 after everything is warmed up. Alternator brushes were replaced a few years ago. During this trip, I bought two new Costco deep cycle batteries and used one Costco battery to power the fridge back at camp during the day while the other charged in the second battery location. At night I powered the fridge and lights from the main battery. The main would barely last overnight and the Costco batteries I swapped out every other day. The Costco batteries outperformed the Platinum battery.
I think I've finally gotten to the point where I want to get this resolved. A week ago my wife went to drive the truck after it had sat for about two weeks and the battery was dead. She drove it and I drove it some more to get the battery charged. Saturday I greased my window runs to try to improve performance and probably cycled the window about 15 times per side. Sunday morning, dead battery. Decided it was time to measure current draw.
I connected my meter inline with the negative battery cable and started pulling fuses with the following results in milliamps. The fuses listed are the only ones that showed any difference in the base reading:
Base 21.3
EFI 19.2
Dome 10.3
ECU-B 19.0
FL Power 18.7
AM1 18.5
I’m running the following accessories:
Fog lights, wired through a Slee harness. No draw in the headlight circuits
12V outlets for fridge, kids games, and misc. No draw in this circuit.
Seat heaters, two circuits. No draw in either circuit.
Automatic charging relay switch. No draw in this circuit.
Voltmeter. No draw in this circuit.
The only thing that jumps out is the dome light circuit, pulling more than 10 mA. I was going to try to locate the relay and check it to see if that is the source of the drain, but it started raining, so I gave up for the day.
Everything I’ve read suggests that any drain less than 25 – 50 mA is probably ok so it would seem my 21.3 mA draw shouldn’t be a problem. I decide to use a little math to see what this type of draw would do to the battery.
So 21.3 mA is 0.021 A. I have a 75 Amp Hr battery so that should give me about 3571 hours, 148 days, or about 5 months before it drew the battery down to 10.5V, which I think is how this is measured. This assumes I understand amp hour rating correctly. Even so, at 21.3 mA, the battery shouldn't go dead in a couple weeks.
I’m stumped on this. I’m probably going to take the battery back to Sears and have them check it, but I really don’t think that is the problem. It seems the charging system is functioning adequately. If the battery is good, the charging system is good, and there is no obvious drain, then my battery shouldn’t be dying on me.
Any thoughts?
Base 21.3
EFI 19.2
Dome 10.3
ECU-B 19.0
FL Power 18.7
AM1 18.5
Any thoughts?
