Common causes of premature burning of the poinst are:
1) Bad/open or weak condensor, or its not wired in as it needs to be or its not well grounded.
2) Excess coil and points current caused by lack of an external series voltage dropping (12 to 6) ballast in cases where its a 6 volt coil on a 12 volt system,,,,,,, or perhaps a bad coil in cases where its a 12 volt (internally ballasted) coil.
3) I dont see the charging system (its regulation) being so bad it can raise the battery voltage so high as to cause points burning as fast as you indicate. It takes a lot of current and energy to raise the voltage on a 12 volt battery to 14.5 like a high amp alternator can while an original generator system has even less output
4) If the distributor shaft has wobble from bad bushings/bearings that can mess up a set of points.
Id be checking the condensor (and its wiring and ground) and the coil to be sure its a 12 volt rated unit and NOT a 6 volt coil which unballasted will burn points faster.
