P401 code fixed itself?
Central Coast, CA
Website
www.coastal-aquariums.com
My CEL has been on for about 3 years now as I am too lazy to dig into my P401 code problem. I just noticed a couple of days ago that the CEL is off. I haven't disconnected the battery lately and even when I do it only takes about 15 minutes of driving to make it go back on. I have done no engine maintanence at all in months other than check and add oil. The light still comes on with all the other startup lights when turning on the rig, but turns off with the others, so I know it's not burnt out. Not complaining by any means, just baffled. Any input here??? thanks in advance
My Engine Light came on for the same code about two weeks ago. I cleared it with my cheapie code checker and it hasn't been on since. Still crossing my fingers!
Dan.
I had an intermittent P0401 code since I bought the truck 15 months ago. It would come and go about every three to four drives and seemed more likely to turn off or turn on after a short stop (like stopping to get gas). I changed the oil a couple months ago and the light has not returned. Maybe something blocking part of the EGR system finally cleared itself, maybe the code will come back tomorrow. I too am happy to have a self healing truck.
Thats whats weird though. It was on for 2 years straight, even when I would reset it or disconnect battery it would come back on quickly and stay on. Now it just goes off and has been off for about a week? Yeah maybe there was a little carbon blockage or something that cleared itself I guess, any other ideas?
Or the bulb finally burnt out!
SERIUOSLY??????? read the first freakin post! It says clear as day that the light still goes on when I turn the cruiser on and then goes off with the rest of the startup lights...why do people post on threads without even reading the OP and then post something worthless???? trying to bump your post count?:bang:
Sorry for the rant, I just don't get it. Seems like a waste of my time and yours. I didn't post this in Chit Chat, I posted it in tech for real thoughts and ideas.
I had a similar thing happen. Except my cel was only on for about 500 miles and I replaced a bunch of stuff. But my truck seemed to self heal.
My guess is that it will be back!! This happened to me too, 2 years of it on then it would turn off, then come back, etc. I doubt that it fixed itself most things that are broken rarely do that, but, you know that!! Maybe temps have gotten colder causing the egr not throw the code? I don't really have an answer, but that is the only thing I can think of!!
Mine would seem to go off and on in the winter, but stay on in the summer, so that's my only guess!!
I found the time one day to go through all the checks, replaced some suspect vacuum hoses (that actually were not too bad) and then drove the truck with a vacuum gauge to confirm proper solenoid operation and the light has not come back on for this code since.
After clearing it one time previously, it came back on with a few miles. Who knows, maybe some x-mas car repair elves were working on the truck while you were sleeping...
Tis the season! So far, this is the most reasonable explanation I have heard.
Yes, it probably will be back, but I'm not sure the colder temps are what caused the change for me. It seemed to cycle every three to four drives regardless of the season during the last year.
It did seem to be linked to an oil change for me. I drained the 5W-30, replaced the filter and added 10w-30. Does anyone have any idea why an oil change might "fix" P0401?
My .02. Have you changed the Vsv yet??? That code can be tripped by a number of things IIRC the gas cap has something to do with it too? Someone confirm im not looking at the FSM .A loose vaccum line was my final culprit. Missed it changing all the Egr innards. up underneath the modulator Maybe you wiggled one on the filter change!!!!
I had an intermittent P0401. Here is what I found.
The EGR VSV would work fine until it got hot. For a long trip, the ECU does not count that as a failure since it worked during the first part of the trip. The ECU must see the failure on 2 or 3 cycles or trips (start, run, ignition off) to set the CEL. If I took a long trip that warmed up the VSV until if failed, then took a few short trips, it popped the P0401 code. If I then took a sequence of trips where the engine cooled off (VSV cooled off) between trips so that the VSV functioned for the beginning of the trip, the P0401 would reset and stay off until I once again took several short trips without the engine cooling off.
This all makes the P0401 look intermittent, but the EGR system works when the VSV is cool, then fails when hot. You get the CEL or not depending on the duration of time between trips.
There is a connector at the top of the engine in front of the throttle body that has conductors for the EGR VSV and the Fuel Regulator VSV. You and check the resistance of the EGR VSV coil at this connector (consult the FSM for pin out). Check it when cool, then when hot. Mine was normal when cool and open circuit when hot.
No oil changes, no vsv change, EGR was changed when I bought it 3+ years ago. Normal driving conditions for me (no extra long trip or anything). I am starting to lean towards elves as well. It will be interesting to see how long it will take to come back on.
That is exactly how mine used to behave. If and when I get P0401, I will check the resistance (hot and cold). So did you replace the VSV for EGR and the problem was fixed?
I was very hesitant to dig in to the issue after reading the FAQ because it sounded like there were about a half dozen reasons for the code, the job was kind of a pain and the truck ran fine either way. Your description is the most accurate description of my problem that I have read. If you fixed your P0401 code just by replacing the VSV for EGR, I will do the same since it sounds like we had the exact same behavior. (assuming my code comes back)
Clemson sounds like he has it right. Mine would only kick on when I drove freeway speeds (between 75-85 mph). It would never kick on driving 55 mph or around town. I did a few of the tests, but the tests on the VSV are deceiving because it will probably only fail at high temps so it's hard to diagnose. I did the VSV for EGR on mine, no more code. FYI I pulled the upper intake off, replaced the vacuum lines, cleaned the TB, replaced fuel filter etc. Not too bad of a job.
Yep, I've decided that if the code returns I will order a VSV for EGR and do the job. It sounds like this can be done without removing the throttle body, but I'll probably use it as an opportunity to clean the TB and replace many of the vacuum lines, etc.
all interesting info, but again, I have not driven outside of the normal conditions that left the light continuously on for 3 years. It will be interesting to see if/when it comes on.
Don't go to the expense and trouble to replace the VSV unless you know it's bad. The down stream connector on top of the engine block is very accessible to check the resistance of the coil (30 to 40 ohms) and you can switch it ON/OFF by putting 12V on the wires at the connector (be careful, best not to use the car battery as a 12V source) and see if it is holding vacuum (valve closed) on the EGR valve when "ON" (energized). The vacumm line goes from the VSV, routed through the intake plenum, then to the EGR valve. You can remove the line from the EGR valve and try to blow air through the line while switching the valve ON/OFF. Or get a vacuum gauge from Harbor Frieght for $12 and a vacuum pump. I used one of those two-cycle oil mixing "syringe" (Northern Tool or Home Depot) to create the vacuum. (That syringe is great for uses other than mixing oil with gas.) Again, you can do this without even seeing the valve. The hardest thing is finding the right pins on the connector. (This is not the connector at the valve.) Don't forget to do this while the engine is cold and then again while hot.
aclos3, no I haven't yet replaced the VSV, but I know for sure that it fails. I plan to pull the intake and do a lot of other stuff while I am in there, valve cover gasket, fuel filter, injector o-rings, etc. I'm waiting until I have a few days to do the work.
There is another good post that explains how to put a tee in the vacuum line and put a vacuum gauge on the dash so you can watch what happens to the EGR valve control vacuum during operation. My VSV works great until it gets hot, then fails open and no more EGR. Run/cool-off cycles determine if/when I get the P0401. Now that the weather is cold, is less frequent. For now I just reset the code when it pops. (Scan tool from Harbor Freight).
Alright, thanks for the additional information. At this point I'll just have to wait to see if it comes back and then i'll go through the troubleshooting you suggested. It was intermittent, although probably less frequent last winter and it has now been gone on my truck since late October.
