p0340 code - CMP - PCM failed?
Denver
Hi. Has anyone come across these issues for their 100series? I have a 2000 LX470. Any help would be appreciated. I'll try to fix this issue myself.
Best!
I've not. But I would start by checking wire to and from cam sensor and the cam sensor itself. So often the wire wrapping down the from DS upper timing cover is not secured properly on cover face, after a timing belt job. It (wires) then rubs on drive belt.
@2001LC you the man. It was exactly as you described. The cam wire dropped down and was rubbing against the drive belt. It ended up slicing it a bit. I swapped it out with a new cam sensor and the code went away. Auto zone had the part too.
