p0304 code help!!
pensacola fl
1995 toyota land cruiser JT3DJ81W0S0094016
starting shaking running rough check code po304 new plugs, wires, cap, rotor 01/18 along with reman motor just installed this year. in June had to pull heater core and fix leak. has been running like new until 3 days ago # 4 plug has some black carbon around porcelain all others were light brownish color. Checked spark, replaced plugs. Also had all 6 injectors cleaned and tested at install time i checked the harness by erg valve this is where i found 2 melted wires before so checked again all still looks good. i checked #4 injector with test light with key on and i have voltage. Almost every vacuum line has been replaced on truck when we did engine swap. what am I missing here any help is welcome Thanks!!
Injectors are triggered by individual ground wires that run back to the ECU. Check continuity from #4 injector back to big plug on ECU. Constant power lead for injectors branches several times around heater valve and EGR. Look them over very carefully.
^^^^ This ^^^^
The wire loom running by the EGR is notorious for causing this problem. I chased all the things you did plus a lot more before I found that 1) my wires were burned at the EGR valve and 2) this killed my ECU.
Here's the thread if you care to read the saga - my code was the same BTW: FIXED!!! Bad ECU - Runs rough, CEL and P0304
i checked ecm terminal for injector #4 had .32 volts all others had 12.50 i wiggle the harness around and it changed to .90 volts but that it. does that mean i have a bad wire going to injector or ecm?
It has ~12v ish at the injector, sounds like a bad connection somewhere between the injector and ECU? Does the injector test correctly, proper ohm range? If so, leave the volt tester connected to the #4 injector, watch it, and wiggle the #4 pigtail and harness in the area, does the reading change. If so attempt to isolate the spot where it makes the most difference.
I don’t about clicking I will check that, does anyone knows the wire color going to the ecm for injector#4
See post #7 in the link I provided earlier for the specific wires and other helpful tips
If you don't have 12v at the injector then I'd say 80% chance you have a wiring issue in the loom going past the EGR and 20% its either ECM or wiring from ECM but before the EGR (meaning where it runs across the glove box support it can chafe there, could also do same exiting the firewall boot).
i have 12 volts on one of the injector wires the other reads .30
One is a +12v and the other is a signal wire. The latter will never show voltage IIRC. The ECU grounds it several times per second which is what fires the injector. If you're running rough, first do the mechanic's stethoscope trick... Mine didn't tick and thus I knew it wasn't firing. From there, work the wiring back from the injector. My guess is you'll find a short by the EGR. If not, work from the ECU forward.
Again, all of your questions are answered, by experts, in my thread. If you haven't already, read it end to end as it's identical to your problem. After you've read everything there and tried the tips that I got, then post back for help.
Good luck!
Jeff
idk i was just using it for comparison, i bought a stethoscope should the injectors tick with key on or does it have to be running?
They should only click when the motor is running.
ok its running i can hear the obvious ticking no tick to #4
Possibly the injector, what is the ohm reading across the connectors? Could be the wiring. The power comes off the Y/R circuit, always on with the key to run, it comes from the EFI relay and powers most of the EFI, so not likely. Ground signal (pulsed) comes from the ECU. The most common fault is at the connector or where the pigtail comes out of the main harness. This is often intermittent, moving, wiggling the harness in the area sometimes reveals the fault. Could be the driver in the ECU, would be very rare.
i will check ohms i wiggled and moved the harness all around and did not change, i have a good extra ecm i swapped out just to try since i had it and no change. what ohm reading should i have on pigtail? can i leave it plugged in while checking? theres no way to unplug it unless i take intake off
IIRC, the injector should be ~14 ohm. Number 4 is not in the easiest spot, but have serviced it by only moving the throttle body. Could check from B+ in the diagnostic box to the yellow wire at the ECU, but would also be checking the harness, so not definitive for the injector.
