p0304 code help!!
thanks, i was able to pull some of the pigtail wire up to probe #4 im not getting any ohms not even a beep
If the injector is open, it's bad.
Don't know if it applies, but we have had a few injectors die shortly after being "serviced". Don't really see anything in the servicing that would cause them to die. But have seen enough that we no longer do them for fun, only if there is a known problem.
thanks Tools R Us, i guess i should of spent the money on new ones instead of having those cleaned :doh: just to much work to get to those injectors!
Other than having them "serviced" they have been very reliable, most that we have had done, didn't need it. Have changed them by just removing the EGR modulator and throttle body, it takes holding your mouth just right, careful tool selection, etc, but easier that removing the upper intake plenum.
will the injector rail come off without pulling intake?
Don't know about "off" but have been able to move it enough to replace an injector.
The rail comes off if you remove the throttle body and egr valve.
Getting it back on does require holding you mouth just so. The stand off plastic spacers and the rail and the 3 bolts have to go back on at the same time. I just did that a few weeks ago.
