- Joined
- Mar 16, 2003
- Threads
- 201
- Messages
- 615
Getting ready to flush the system after new install of "OEM' setup. Just a couple of questions....
(1) Manual says to use Dextron type ATF, all I can find is Dextron II ATF, is this O.K.? I take it that I am not using P/S fluid...
(2) To flush the pump my plan is to run fresh fluid thru the top of the pump resevoir, and catch what comes out the H/P line. Will spinning the pump pulley by hand suffice to push fluid thru the pump and out the H/P line?
(3) Do I need to flush the P/S gearbox? It's a new remanufactured OEM P/S gearbox from Cruiserparts.net.
Any other insight/tips/techniques are appreciated...
Keep on Cruising!
Dave
Keep on Cruising!
Dave
