Overheating. Options?
Finailly cool
I have finally solved my problem. Moved clutch fan closer to rad with an extender. Got a new schroud from a volvo, electric fan as a pusher and a 160 thermo. Ran yesterday in 85 weather and never reached past 180.
Will probably change to a higher thermo. But used to run about 210-220.
Do not think I will need that new fancy aluminum rad.
Add a shroud. You can also add a piece of sheet alum between the grill and the front of the rad to make the fan suck in outside air.
Ditch the wimpy fan. 7 blade, deep pitch. You can get the asymetric bladed fans to lessen fan noise. Consider an auxillary pusher fan, too.
Do you have headers?
fj40charles said:
No, it does not bother me. A TBI motor uses a 195* thermostat. Mine runs around 210 when wheeling and around 215 to 220* when on the highway. I have a big ass Griffin radiator, fan shroud, and clutch fan.
Thanks - that is cool to hear!
My 40 runs 180 / no TBI tops out at 200......
My 60 runs 200 with a TBI - 220 if towing -
both have 4 core radiators -
the 60 has a shroud......and a huge hole in the hood with cowl induction
You can also run the new antifreeze, DexCool. It cools better and lubes the waterpump better than the old. It is recommended to run it at 70% coolant and 30% water. One of the benifits is here in the north, the stuff will protect down to -80 degrees or so. The stuff works great.
I suggest against the Dexcool or at the VERY LEAST be sure you don't mix them!
DexCool Thread: http://www.hotrodders.com/showthread.php?t=24012&page=1&pp=15
That is for sure. I made sure I did a flush and clean when I did it to prep the system. But if your having overheating problems, seems like a good cleaning of all the rust out of the system is a good step also.
I also had a friend that had to steam clean his engine from the inside to get all the gel out of it. But the benifites of the Dexcool are well worth the time IMO and I've changed several older vehicles over in the past.
I Had A Custom High Density Radiator Made By The Same Guy Who Makes The Radiators For Tlc On Their Vortec Conversions. It Ran About $200, Had To Cut The Old Radiator Mounts And Drop Them About Three Inches And Off Set To The Right. Using A 180 Deg Thermosat And A Flex Fan. Was Running 235 Deg, Now At 170 Deg.
I'm running a crate 350 with a 4 core rad and an electric pusher fan and usually run 190 from idle to 65 mph. 70-75mph it goes up to 200deg. I have two sensors the stock toyota in the intake manafold and a mechanical in the the passenger side of the block.
If heating while at speed rather than in traffic it usually points to the radiator being the weak link provided your pusher is not blocking air. If you have room for it puller fans are more efficient and move more air. Still, 200 is not bad as long as that's worst case scenario.
Ya I'd like to have a puller but have no room. I figured that 200 wasn't bad. If I slow to 60-65 for a few miles then it drops down to 190-195 preatty quick. I could impove it by moving my heater by pass to another location and going to a bigger bottom hose on the rad. But I figure that I really don't drive that fast that offten and it keeps at 190 when wheeling so I'm happy. Thanks for the input. You guys rock.
Andy
Do you mind sharing this guy's contact info?
An update...
I spent Saturday afternoon throwing in a Taurus fan. Haven't had it in the dirt yet, but in heavy traffic stop and go was no problem. The needle never went over 180.
Stock Radiator, w/ high flow 160 thermostat, taurus fan seems to taken care of it.
