1991 With 118k miles.
Looked around on this tech section and it looks like this is a pretty common problem with the 80's. It hasn't been too bad a problem for the most part. I've had a few times where it got high on the Temp gage, then when I got home I added some coolant or water to top off the radiator. I don't think it's leaking into the engine. There's no white smoke or milky oil. I replaced the plastic radiator with a fully metal one a while back(Re-Used the old cap). Still have not replaced the Thermostat or fan clutch yet. The last maintenance I had to do was the Alternator 2 weeks ago.
This morning it got really hot really fast. Usually it will cool off somewhat, but it threw the check engine light and was not backing down. My morning commute is only about 7 miles and it got that hot that quick. Outside temp was in the 80's I think. By the time I got there it was spewing steam out the overflow tube pretty bad.
I should be able to test the fan clutch, but I guess the Thermostat is a dive right in project. Will probably replace that one either way.
Any other suggestions other than the basics for now??
Also, side note, what's the PHH everyone is talking about??
