I have a 89 bj74. 13bt with 200,000 KM. I am having an issue with the truck overheating. It is not a consistent overheat but when it goes it goes.
I have installed a mechanical temp gauge before and after the thermostat last week. I have driven it everyday in lots of different situations with no problems. Warms up to 190 and then runs constantly at between 190 and 199. I have run up steep hills and around town. IF you really get on it I can get it to the 199 mark but never over that.
Today I took it on a several hour trip down through the mountains and had a good run with consistent temps for the first hour and 1/2 and then I noticed it climb to 201 for the first time. I slowed down a bit and turned on the heater and nothing but cold air. Pulled over and let it idle and it reading went to 230. At this point i can hear the fluid gurgling and have steam in the engine compartment. The reservoir is full and steaming.
I shut it down and wait 20 min or so for the temp to return to around 210 and then i start it up. Cold air out of heater but constant temp on gauge.
I start driving easy down the road and the temp drops to 190. Within a mile or so the heat starts woking and I continue on to town 10 miles or so and stop to get water with no issues.
I let it sit for 30 min or so and ad about 1/2 gallon of water. Temp on truck shows 130. I start up again and let it idle but again have no heat. Let it run for few min and then start driving. Heat comes back and I go for another hour of easy highway driving before I again start the overheating issue again.
First the temp climbs to 201, then the air goes cold. Then the temp spike up to 235 range. Losing coolant out of the overflow.
I find the issue very strange. I can let it cool and then it will hold its own for a bit. Hard climbs don't effect it. The on constant is that as long as it is below 199 its great but the second it goes above 200 it a chain reaction that can't be stopped.
Here is a list of repairs.
New thremostat
New water pump
new hoses
flused and red installed.
Had fluid tested and no carbon monoxide present so no combustion mix.
I really don't believe its a head problem as it can't be recreated by extreme acceleration or hard use and I can drive it around town for days with no issues.
I am leaning towards some kind of hose blockage or collapse but any thoughts would be helpful.
New thremostat
New water pump
new hoses
