Overheating 13bt. Coolant flow issues
I am very curious about the tranny being the root of the problem. I will look at how i can hook up a mechanical temp gauge to the system to get a better reading on that as well.
Had fluid tested and no carbon monoxide present so no combustion mix.
Just re-read this and I'm not sure I understand. I have a combustion gas test kit for diesel engines. This one uses a single fluid type for diesel or gasoline engines. There's also a different brand that uses different test fluids for diesel or gasoline. Did you use something like this?
I don't know how the CO test works. Not familiar with that.
Yes, that is the test i was talking about. Combustion gas=ehaust gas=carbon monoxide. Combustion gas is what i was referring to.
Ok, answered my own question about the carbon monoxide test.
Looks like the average diesel engine produces about 2% of the CO that a gasoline engine produces pre-exhaust treatment. So a CO-only test is unlikely to accurately indicate the presence of combustion gasses in a diesel's cooling system.
Sounds like you and wheelingnob have alot in common. Might want to read his isuzu 4but build. He too was spitting out fluid , over heating , loosing boost , and now is plagued with transmission troubles . Oh and he also went the gas tester route too. He had alot of mud support that you might be able to use before it starts compounding.
The clue to this problem is in not getting any heat from the heater. A Head or tranny problem would not cause that.
Lack of water in the heater core would prevent heat from the heater. What's causing the the water to leave the engine?
If water is leaving the engine ,it would be from expansion. I bet the heater is full of cold water because something is blocking the flow.
If it was my problem, I would be looking at the cheap options before looking at blown head$ and over heating tranny$
I'm trying to understand. The the radiator cap is releasing coolant from the system after an hour of driving at highway speeds. The engine is overheating due to something blocking the water flow to the heater core?
Yes but it could be a blockage in the water jacket. I would undo the heater hoses and see if the heater matrix is empty or full.It would also be a good time to back flush the matrix with the garden hose.
I am not sure how the heater could be full of cold water if it works great for a week at a time and then goes cold a few min before the overheating cascade starts. I really feel like the heater is just a symptom of the problem but will look into that closer.
Took the truck on a 3 day camping trip in the rich land creek wilderness area. Hauled it on a trailer for the 100 mile highway trip and then did 166 miles of trails. No overheating issues with lots of slow driving. On the way out I did have a good hour run at about 30 to 40 mph and while the truck didn't overheat it did slowly push enough fluid out that the it halfway filled the reservoir bottle.
So the heater works sometimes? I agree ,it is only a symptom but a strange one. The heater matrix could be full of steam ,not sure if steam would give off much heat. I seem to remember a big debate about it once before with no clear result :rolleyes:
Clear high heat silicone hose would show flow know? My understanding of block ,head or gasket failure, is that the air that leaks causes no flow of water to that particular area, and then puts air into your system , no matter how small or where ever it is. Any gas tests you do it should be done and checked at the time the symptoms are actually happening. .
Have you actually done the simple heater bypass at block, like everyone agrees should be the first thing to do?
I can do a heater bypass but don't understand how that would change anything. The heat works fine until I do a sustained highway speed drive. The heat quits just seconds before the systems goes into overheat mode. No fluctuation in temp. A steady 195 to 200. I can power up long hills or spend the day crawling with no problems. I understand that heat stops because of steam in the lines or some kind of blockage but I can not see how that would put the system into a tailspin and overheat. I have never been around a truck that won't go above 200 unless its on a unstoppable overheat.
I can see how the transmission could be overheating transmission cooler and when it boils the the result causes a series of events that the trucks cooling system can't stop. I feel like if the engine was causing the problem then I would see temps slowly rising above 200 until it overheated.
I have tested the for gas just after the last overheat before adding any new fluids with negative results. My next step is to look at a different type of transmission cooler.
Also within about 15 min or so after an episode the heat comes back as soon as i start driving again.
My thinking is if a gasket fails it fails , if the head is bent it compromises the gasket to no return, but a crack can open and close continuously till one of the above happen..If you were real lucky could it be loose head bolts ?
Could it be the viscous fan slipping ? The higher the temps the higher the pressure in the system and rad cap is opening at the higher pressure. I had a toyota 82C termostat that after a year or so went failty and did'nt open till 88C/89C.
