- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
RavenTai said:thanks for illistrating that Tools, I have been ignoring those air dams did not figure they made much of a diffrence, picturing recycling hot air I can see how they could.
several of mine need to be replaced does home improvemnt type foam hold up to the heat? I coudl use 2" aluminum tape but that would be ugly.
The standard stuff holds water gets heavy and falls out, the high density closed cell warerproof stuff works well. The trick is to pinch it between the parts that your sealing, if the gap is 1/2" use 1" or thicker foam, loosen the part and push it back, opening the gap, apply the foam and reassemble trapping the foam in the gap.
The bigger stuff is sometimes in the garage door section of the store.
