I see people that have these leaking and other that just look like clean bare steel. Mine look like this. I take there a something else that seals these? If I did a rebuild sometime next summer can I clean these up and maybe powder coat them?
by the way where are you located that is a good amount of rust
Did you find that in the bottom of the ocean, looks like nature's property already.
Anyone know if the entire knuckle ball comes from the factory painted, or would it be OK to paint them when everything is apart for the front axle service??
ok I'll have to pull that plug tonight. Do the front wheels have to come off? What grease should I use, and is it like the Diff where you fill it to the top of the filler hole?
...You can try to stick a long screwdriver down there or similar but IMO that really doesn't tell you much other than if there is some grease in there or none
