I always thought the Patrols were neat even if they do look like the bast**d spawn of a wayward Land Cruiser and some floozy Series II Rover.
Wheel spacers explained.
You make an excellent point. I had not considered that situation.Depends ...
If <key word here> an appropriate spacer is used with a wheel that has too much backspace compared to OE, it can be used to get backspace, offset, track, and steering geometry back to OE specs.
I had to do this on the 73 when I went to larger diameter wheels since the OEM backspace / offset was unavailable. The result was backspace and offset that was approximately 3/16th of an inch off of stock specs ....
Depends ...
So I can play Pandora through my stereo with this device? If yes, ordering now.
ordered.
thanks for sharing and much needed.
Basically turned the old fm stereo into a mini jam box that we have in the house.
Depends ...
I watched the video, it was good,(and I've since watched a few of his others) but I also went in with a bias.
I already have a dislike of spacers, but the fact that the video was sponsored by a manufacturer of spacer lead me to further discount the positives he mentioned.
Major points (exempting situations where you are using them to with an aftermarket rim to RETURN stock geometry)
Screws up bearings.
Screws up suspension
Screws up steering
Increases tire wear
May give slight stability enhancement.
May prevent some rub from a wider tire (BUT change of steering geometry can actually CAUSE rub)
Seems to me like a net negative.
I know out my way, I see these trucks on the beach with silly-wide stances, and just shake my head. Are these guys really coming so close to the edge regularly that they need to widen the stance? AND if that's the case, maybe the massive lift, should be dropped a bit. You'll get a lot more stability lowering an inch than widening by an inch.
My $0.02 - There are a FEW good uses - Sam and Stan covered that ground. Beyond that, this is a mod high on aesthetics and low on function. But hey, I think skinny tires are better too, so...
Now I will complete no work today. I have put forth an opinion on the internet and now must remain vigilant so I can angrily lash out with personal attacks at anyone who disagrees.
Obvious but not yet mentioned is outboard loading of the spindle making them easier to break.
Here is someone that obviously holds several physics degrees:
