One Brake Locks Up.
North Front Range, CO
My Passenger side rear brake locks up before the driver side. I am not asking why the rear locks up before the front, I know why. I want to know why one caliper grabs more than the other.
ABS and LSPV removed. Brakes have been bleed many times.
I replaced both calipers (rebuilt Toyota) ADB slotted rotors, EBC Greenstuff pads under 2 years ago.
With and without a proportioning valve the brake still locked up but the other side didn't.
I haven't removed the wheels to check pad ware yet but will this weekend.
It has original brake hoses on it. Could a line be swollen? How can I check it?
Could there be a problem with the rebuilt caliper? Other place to look?
A swollen brake line will likely affect all brakes evenly. My bet would be a caliper problem although it would be kinda surprising with relatively new Toyota parts. Maybe its something silly like one rotor got grease on it and wasn't properly cleaned? You could try swapping the driver side pads with the passenger side pads to see if that changes anything.
The only things I can think of are one caliper has a stuck piston and maybe there is a different amount of disk contact/wear.
I'd visually inspect and get rotors turned if something looks strange.
yes, with a floating caliper design, such as in the rear, the piston pushes out against the inner pad forcing the caliper away from the rotor. the slider pins in the bracket allow the pads on the outside to make contact with the rotor as they are fixed to the caliper body. with a seized slider pin your pretty much using the inner pad only not both and cutting down on how effective that caliper is working
Disc brake - Wikipedia, the free encyclopedia, a little reading if I didn't explain it well, caliper section is about 2/3 down the page
when you lube the pins you will need a silicone based grease, petroleum based will swell and destroy the boots. you can get a 100g tube from the dealership and it will last quite a few years as you don't need all that much per pin
I have been using Sil-Glyde
Sil-Glyde Brake Lubricant is a silicone-based brake lubricant recommended for the entire brake assembly, is compatible with plastic and rubber (EPDM & Nitrile), and dampens vibrations between contact points. It is moisture-proof and heat resistant to over 425 degrees F (218 degrees C), which means it won’t burn-off like other brake noise products. Its long-lasting properties provide a noise-free brake installation and easy disassembly. Using AGS brake lubricant is one of the keys to eliminating disc brake squeal and protecting parts from corrosion and rust.
Is this the correct stuff to use on the pins?
Y
Yes it should be used on the pins as well as where the pads make contact with the brake bracket hardware. I put it underneath the hardware also if salt is used for road ice.
