We get owners wanting to do this all the time. You need a huge lift for the oil pan to clear the diff. These are good engines in their appropriate vehicle, but a Landcruiser is too small to handle the noise and vibration. They often end up in the classifieds within a year.
Cheap is not always good.
Toyota/Hino/Daihatsu make engines in the same class as the Cummins 6AT for their trucks, but they chose to make a 6 cyl diesel for the Landcruiser
Thats intresting about the huge lift to clear the oil pan? I have taken the springs out of mine and had it sitting on the bump stops. The pan sump sits rear of the tie rod, the only clearance issue on full bump is the front drive shaft gets really close to the flywheel housing.
This is a 6bt tho so maybe the 6AT is different?
As far as noise and vibration go the 80 does a good job of insulating the occupants from it. Mine is a Lexus with a bit more sound insulation than a Land Cruiser. With the windows closed I would say it's no worse than a 60 series with a 2H.
To each there own but giving opinions based off of nothing but trucks turning up in classifieds is silly. I have seen based off the classifieds that most where selling them due to poor installs or lack of mechanical skills to maintain or work on it.
Are you talking about a 6BT cummins? The Onan l634t is smaller and sometimes called a 6A cummins
I can’t find wiring diagrams on the internet to help trace back ignition wires. Would the fuel pump have to be ran on a solenoid or just tie into the ignition switch?
