OME springs & shocks install
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
Slee says:
Step 1:
Make sure the vehicle is parked on a flat paved area. If doing the front suspension first, block the rear wheels. Jack the truck up using a floor jack placed under the front axle. Now insert the jack stands to support the frame on each side, right behind the front control arm mounting point. Do the driver side (DS) then the passenger side (PS).
I believe this is the location furthest to the front of the axle but still behind the control arm. If I do that, the front sags too much. The front of that control arm is on the axle though.? Correct?
Does someone have a picture that shows where the Jack stand is better placed
You answered in your post.
Place jack stand on frame.
Right behind rear most (frame end)bolt in front control arm
How can it sag too much? You are wanting sag so that you can pull springs out after removing shocks and droops even further. Still may take a guy standing in Hub to be able to get spring out.
So my placement is probably OK. I just need to jack it up higher so that the rotor doesn't hit the ground.
Good luck! :flipoff2: (I think that's obligatory)
I got past all of that. Now my issue is that the nut does not go on to the bottom of the shock as shown. Now what? The threads are hosed.
Time to head to your favorite tool supply store. I highly recommend anyone working on older rigs should own a tap and die set.
I think you can buy sets just for chasing threads as well. Super easy and not too spendy.
I got a cheap metric tap and die set from NAPA like 15 years ago and couldn't be happier! Only need them a couple times a year but they have saved me a few times.
As far as original question, yes, you need big arse jack stands. No one seems to mention that in posts though. I had to buy the biggest ones I could find to make work, and even then I have to stick some 4x4s under them sometimes in a pinch.
Picked up the 12 X1 .25 die and when finished put on the nut it stripped. Then I tried 7/16 X 20 same thing. Now I am at 7/16 X 14 and we will see what happens.
Yea welder it is a necessity
