OME spring question
Western WA
I want to take a leaf or two out of my OME heavy springs. Can I do it while they are in the vehicle?
Yes you can just support the vehicle by the frame and at the axle. It can be a struggle to get everything lined back up. A ratchet strap will be helpful.
I just did this on my 40. 2.5 ome lift. Bottom 3 off the front and one off the rear leaving the overload spring. Sits level and the shackle angle is better. I have 31/10.50 bfg and it looks just a bit taller than stock. Flexes better too. Pic with the doors off is before I removed the springs. Hope this helps.
Thanks that helps me a lot
A couple of big clamps and a long bolt or rod in the spring pin hole to help line up the springs when you tighten up the clamps that are position on either side of the pins hole. Once the springs are clamp tight install the center pin bolt.
I supported mine with jack stands in front and behind each axle when I dropped both axles to rebuild and then replaced the springs.
I have a Con a Fer rear bumper and used that to support the rear and they others had 6 stands under mine. I still did not feel comfortable working under it because I have had friends that have there car or trailer fall on them.
Can you take a picture of the springs so we can see what that looks like? I would have been scared to take 3 off at once
2f motor, warn 8000 and aluminum tub. Sits and rides nice.
Very nice - thank you! I have some unknown springs on my mine and they seem to be good quality but maybe a little stiff. something I'll be looking at in the future
I had a 2.5 inch pinnacle springs from jto some twenty years ago that I had to remove several leaf springs to get it to soften up and not bounce me to death. Trial and error. My 40 doesn’t get loaded with more than one person and a weekend of gear.
That said my ome springs ate much better quality, I just needed to fine tune them for my application. Good luck.
My man. I love that Aussie Bar. I am also trying to make Aussie Bars Great Again!
Can you please take a picture of the front spring pack at the axle? Thanks
Can a rear leaf spring be put on backwards and cause the angle of the back shackled to be different as well as lean to the left? I have a HELL FOR STOUT lift with leveling block on the RR spring but the LR still 1.25" lower lean and what appears to be a more compressed? angled shackle
