OME Leaf Removal
Christchurch, NZ
Website
www.halthass.co.nz
Anyone have any solid recommendations for which leaf(s) to remove from my OME 4" lift?
My shackle angle is crap and my flex is pretty poor.
The rear leaf packs have 7 leaves (the front have 9), I was thinking i'd remove the 2nd and 4th shortest ones as they don't have clamps on them.
Any ideas?
Thanks.
Hi All:
First off, the OME suspension for a 40 Series only gives about two inches (50mm) of lift over stock ride height.
Regarding poor flex and shackle angles, the SBC V-8 you've got in your rig is about 120 kilos (250 lbs.) lighter in weight than the Toyota engine (2F, 3B) would be, thus the spring rate is too high for the application.
IIRC, you'll want to remove either the third, or fourth leaves from the top of the pack (whichever do not have the spring clips attached.)
Question, what shackles are you using on the rig?
Good luck!
Alan
I'm not sure about the shackles - i'll take a picture and post. I'm pretty sure there's more than 2" lift in these springs, I run 35's with about 8 - 9 inches of open air between the top of the tire and the body. The body is lifted 2" as well however.
Thanks for the recommendations, i'm half way through removing springs 2 and 4 at the back and will see how that goes, the clips are on 1 and 3 (from the bottom) which is 4 and 7 from the top.
Cheers
I was actually wondering about this the other day. I have the OME springs and the SBC.
but, even in the rear the spring rate is non existent. I removed the overload springs in the back The ones that are basically flat. My guess is that this did no good in helping with the ride because they are not engaged in springin most of the time.
I read on this site a while back that removing a spring is good for a better ride but, I have not seen a really good write up on it.
think it was the 2nd or 3rd leaf ARB told me to remove, I did on both my 45 and 40
Buddy King at ARB told me last week to remove the third spring from the top to reduce the spring rate on our OME 2.5" setup.
We left it in, because both me and Dad think the ride is great, but it was definitely the 3rd from the top that was suggested to be removed.
Dan
Just an update - I removed springs 2 and 4 from the bottom for all four leaf packs, it rides a helluva lot better now and flexs more. My shackle angle at the rear is at least on the right side of vertical now, the fronts are still pretty much dead straight. May take another leaf out of the front and see how that goes.
Thanks for all advice etc.
