OME J's progressive rate?
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
Ok, so I'm sick of my heavy duty King Springs and I'm going to replace them with something softer. They are great to carry load and they don't sag even under 600lbs, but, unloaded, they are a real pain.
I've been taking a look at the OME technical info that Retrofive kindly refer me to: https://forum.ih8mud.com/469977-post3.html
Here's stated that the OME863J have a 19mm bar diameter and 265lbs of spring rate.
My springs also have 19mm bar diameter and 300lbs of spring rate, but the dealer that sells both King Springs and OME, says the 863J would be much softer, can those 35lbs in spring rate make such a difference?
Taking a look as slee's table, it looks that these springs are progressive rate as they are rated to loads from 200 to 440lbs.
Slee - Springs
Funny enough, the 863 are rated the same as the J's in the slee website, but in the ih8mud table the 863 have a spring rate of 250lbs against the 265lbs of the J's.
If I mount OME 850J in the front and 863J in the rear I think I will have quite a high ass, as my engine is diesel, I have dual batteries and a winch. I have 3cm trim packers for the front, would it sit level with that?
And, the most important thing: for those that are running OME J's, is the ride harsh or too firm when unloaded?. Do they sag much under load?
Have you considered FOR suspension? Sounds like it be what your looking for. I haven't driving on them, but people have spoken highly of the setup.
With a diesel (which i'm assuming is much heavier than the 1FZ-FE) a winch and dual batteries I would go with J's in the front only. I ran 850J's in the front and regular 863's in the rear for a while and it was a very level stance. That was without a winch or dual batteries, but with an ARB front bumper. In your case the rear should sit a bit higher with standard 863's in the rear and J's up front. I guess it also depends on how much stuff you carry around regularly. If you're carrying heavy loads often then the J's in the rear may make sense. The ride is not overly harsh but definitely not as smooth as the F.O.R. springs I have now.
The 1HD-T aren't really much more heavy than the 1FZ-FE anycase. .
I have a J front and regular 863 rear with a front 1" aprox spacer and love the stance .. complete leveled ( and a bit higher front ) .. just I'm little obsesed with the leveled trucs ..
great combo anycase ..
and yes 35lbs make a huge diference ..
I have a trim packer of 1.18" to put in the front, so I may try OME850J in the front and OME863J in the rear.
I like the back to sit a little higher unloaded but not too much. I also have a spare wheel tire carrier with a steel wheel.
By the way, I have thought about the F.O.R. springs, but I don't know if the sell them individually without the kit, plus I have to pay shipping and customs, but maybe the extra spending is worth.
Do you know if it's possible to buy only the F.O.R. springs?
I think Frankie will sell the springs only for $600
i think you ought to go with the Slee 4" heavies, a set of air lift air bags in the rear and be done with it! It sounds like your weight variance is drastic enough to warrant two different spring rates in the rear. The OME springs will get tired if you keep loading it like you want to over a long term period. I used to have the 850J/863 combo in the past.
I'm also having a hard time believing that the OME springs for the landcruisers are progressive rate.
Just my .02 cents. PM me if you want to chat more extensively about this.
Thank you.
But the Slee 4" heavies are much stiffer than what I got now, and I want to go softer.
For instance, the spring rate on mines is 300lbs, and OME 864 is 320.
In terms of load carrying capacity, the Slee heavies are 500-700 lbs, and the OME 864 300-600 lbs. Even the Slee medium would be stiffer.
I have enough carrying capacity now, as they don't even sag after loading the truck with 600lbs, but unloaded it's a nightmare.
I know the OME 863 or 863J will sag after a few expeditions completely loaded. I may consider the airbags. I've read that they hurt articulation but what can I do?
By the way, what's the optimum load range of the F.O.R. springs?
What kind of a load, if any, do you have in the rear in terms of bumper, cargo drawers, etc? Sorry if you've mentioned this already.
I suggested the Slee heavies because over time, you may end up adding more permanent equipment in the back and the rear height will stay as it should. I started with the Slee non heavies but went with the heavies in the rear after about two years. Couple of other 80 owners I know have or would like to make the same switch given the amount of constant load that exists in the rear of their vehicles.
The air bags won't limit your articulation enough to be a concern, IMHO. I mean, if you're hauling 600 lbs of cargo in the rear, plus passengers, I don't think you're going to be doing extreme rock crawling where rear suspension articulation, or the lack there of, is a huge concern at that moment! :-)
Just my .02 pesos...
Slee - Springs
Those figures are not spring rates. They are the added weight over stock that the spring was designed for. In other words, with that weight on the truck all the time, the spring will yield the lift it was designed for.
but with the airbags .. you must have they with pressure even if you are not loaded .. so add in your ecuation.
My dealer says that the OME863 and 863J have both the same 250 lbf/inch spring rate. I talked with another ARB representative and he confirmed that, and the same in an OME table I downloaded from Cruiser Outfitters, so the 265 lbf/inch showed for the OME863J in the table above must be wrong.
The mentioned table shows the same:
OME 850J: 525/535 free height, 17mm bar diameter, 220 lbf/inch spring rate.
OME863J: 510/520 free height, 19mm bar diameter, 250 lbf/inch spring rate.
And this in the IH8MUD table:
OME 850J: 515/525 free height, 17mm bar diameter, 220 lbf/inch spring rate.
OME863J: 505/515 free height, 19mm bar diameter, 265 lbf/inch spring rate.
And for the King springs, the dealer sent me a table that also doesn't match what King Springs emailed me from Australia:
Dealer:
KTFR-69HD: 240 lbf/inch
KTRR70-HD: 305 lbf/inch, 490 free height, 20mm bar diameter
King Springs Australia:
KTFR-69HD: 260 lbf/inch
KTRR70HD: 300 lbf/inch, 495 free height, 19mm bar diameter.
To make things worse, I found a King Springs table in a french forum that is a mixed report between the data of the dealer and the King Springs Australia email.
This is hopeless!. I'm trying to compare my present springs with the new ones to calculate the height difference exactly cause I don't want to go higher or lower.
Well I just been taking measurement on some brand new King Springs that are still to be installed and, as I should have guessed, King Springs Australia information is the right one. I'm waiting for the response from ARB to confirm either table and then I will be able to compare springs properly.
I have J's and I think they are way too soft. I have an ARB front bumper (no winch yet), Kaymar rear bumper, Engle fridge, and 24 gal aux tank.
J's are just too soft unloaded or loaded for me.
I'll switch to Slee 4" soon.
Stated spring rate is only one variable in a spring. If you want real advice here, post up your rig specs (heavy bumpers, expedition storage, none of the above?) and intended usage.
You can't really compare springs just by spring rate in a meaningful way unless they are from the same manufacturer.
I just recieved an email from ARB Australia and they confirmed the next data for the springs:
My King Springs:
KTFR-69HD: 515/525 free heigth, 17mm bar diameer, 260 lbf/inch spring rate.
KTRR-70HD: 480/490 free height, 19mm bar diameter, 300 lbf/inch spring rate.
So, I think I'm keeping the King Springs in the front, as I don't want to lose height and I will with the OME850J as they are the same lenght with lower spring rate, specially since I'm adding a 12000lbs winch.
My biggest doubt now is about what to do in the rear, keeping the King Springs or replacing with 863J.
The 863J are 1" longer but 35lbf/inch lower spring rate, so the rear is likely to sit about the same height unloaded, isn't it?. It's a bit like comparing 863J with 864 (480/490 free height, 320 lbf/inch spring rate).
Well, I can't just by spring rate, but I should be able to do it if I include free height, bar diameter and number of coils, shoudn't I?
Maybe you are right as there is one factor that's difficult to measure, that's steel quality and temple (I don't know if that's a right word for it in english).
Anyway, you are right that I should post the specs and equipement:
In the front, I have a tubular bullbar now, but they are being banned in Spain for safety reasons now, so I'm removing it and adding an iron bumper ARB style but without the bars. The guy that's making it says it won't be much heavier than the stock bumper. I'm also adding a 12000lbs winch I bought at a bargain price from ebay (I hope it works). Also a diesel engine (not much heavier than the 1FZ-FE as Tapage said) and dual batteries.
In the rear, I have the stock tire carrier with a 285/75/16 with a steel wheel and some recovery gear and tools weighing no more than 100 lbs. But when I go on long expeditions I'm carrying between 400-500 lbs.
I know that I can't have everything and if I want to be able to carry heavy loads I have to be a little uncomfortable when unloaded, but these King Springs are a bit too much. But they are great when loaded and they sag just 1" with 600 lbs on. So it's a difficult decision.
I wouldn't go to a J spring for those kind of loads, personally.
The loaded to unloaded setup speaks well to trying the FOR springs as they are progressive, but adding 600 lbs may push you past the benefit of the progressive rate in the sense that you will get more compression before the stiffer base rate is achieved. In other words, you may need to keep the rear higher than you want unloaded.
You might keep the stiffer springs and go with a high end shock like Fox or Bilstein 7100's. People who are running higher rate springs and have switched to a high end shock have reported dramatic improvements. That's probably where I would spend my $$$ in your position, because it isn't that easy to get a coil spring itself to ride harshly - granted I don't know a whole lot about King Springs.
Still, it is in combination with a mediocre highly valved shock that a coil suspension is likely to be harsh more than a 10% difference in spring rate, so if you like your springs for the performance end of your usage (highly loaded expedition), then run a high end shock like Fox and you'll see huge improvements. What shocks are you running now?
