How much torque your guessing to make?
Right around 350ft-lbs would be my initial guess. We’ll see when it gets finished!
How much torque you’re guessing to make?
Lighter than a 3FE!OM606 are tough as nails but HEAVY.
compared to other 6 cyl diesels its light.OM606 are tough as nails but HEAVY.
Fab parts included capping off the EGT port on the oem turbo manifold. I tug welded it with a nickel alloy rod as the manifold is NiCr. The water pump housing had a tube coming out of the back that almost did a 180 degree turn. I welded a bung onto that to remove the need for a o-ring fitted tube as it was leaking.View attachment 4139673View attachment 4139676
Benzforce is in the US and they do Pumps with Dieselmeiken partnership.Very nice!
Ill be using SendCutSend for my firetruck conversion in the not so distant future!
Superfastmatt seems to have really good luck with them & im impresed with their work.
Im asuming you're doing some fueling upgrades to make more power?
Dpuk has come a long way with his 606 offerings. Prior to him it was limited to Myna or Diselmeken. Unfortunately for bolt-on fueling enhancements your only option is a modified Bosch M-pump from an OM603 which has always been expensive and nobody in the States is setup to do M pumps. The UK or Europe are the places to go to.
Somewhat recently theres been some new, highly efficient air-to-water 3D printed intercoolers being developed. I wouldn't mind running one of those on my 1HZ when the time comes but they are probably very expensive.
200 lbs less than the 3FE and with a Pump and Turbo will make double the power and get better fuel economy.OM606 are tough as nails but HEAVY.
I have been researching this as well. I too am doing an OM606 swap and want to use the A440F as it fully mechanical. My understanding is that they are about the same as the later model and they hold up just fine with 3FE. The 606 will be 250-280HP though and I hear that you can rebuild with new valve body and it males it solid. What experience are you sharing that suggests the transmission will fail?Nice work!!! Ditch the a440f transmission. It fails. Likely to fail sooner with the OM606.
