Old School Hard Top
Nomad - www.wegonow.net
I searched FAQ and other areas. I must be using the wrong key words "hard top".. I get no results.
On to my question. I just picked up a HT for my 66 40. This top is from a 66 40. It has the small vent delio in the top, at least the hole is there. all the actual vent is not.
Q1) What year 40s had the old corrugated type top with the cool rear gate/window dealio. SOR state 62-63 had these , then some gaskets go to 69
Q2) Where is the best parts source for these old tops? I need gaskets n such for retsto..
Thanks!!
Corrugated tops ended in mid '65.
By no means am I an expert, but looks like you have a '64 or '65 hard top.
As far as parts go...not that easy. Mark has a few tops, so he may have some parts. SOR has some stuff, and even CCOT may have a rain gutter (it's a kit in parts) that might be made to fit...just know that it won't be an easy go at it, as these tops are not exactly the same width as newer tops.
I love my old top, and purchased a second just because parts are that much harder to find...(plus my roof panel is in bad shape) actually looks like I might have to fab some stuff myself,...and it's all good because these are the coolest tops out there :beer:
Hey...did you get two whole tops??
I'm not certain, but I think you have to run different doors with the early corrugated top as well. The upper weatherstrip (for door) is on the top rather than along the top edge of the door.
My doors are correct for this top. Thats why i got it. I had a newer top, it did not fit
Shreg,
I'd put this in the 25 section it might help you find the parts you need.
I did not. The only good parts left from the second one were sides and rear door. No fiberglass. But, the extra parts were in good shape. Allegedly from a 67..
So, i am positive my 40 is a 66. That said those tops must have been used up to 1966. AND, the second top was off of a 67. That just adds more uncertainty.
Good news is i may have located a "vent" for the top. I need gaskts and the resto can begin...
That I know, these tops finished in mid '65. So who knows?
If it's only the glass panel your after, I know of one that was available in CO....and might still be, or...you can use your good one to make a quick mold, and make yourself a second one (that's what I'll be doing).
Cool you found the vent...not all corrugated tops had roof vents!
Im good on the glass, that was carried separately but was included with this top.
If there are any pics out there of a complete top with roof vent detail i would love to see them... I will wander over to the 25 section and see what i can find
like others said, the corrugated tops ended sometime in 65, the vent for the top was not used in 65, not sure when it ended, I know 63's had them, prolly 64 as well
corrugated top doors can only be used on corrugated top 40's unless you change the front window frame, they will fit but leave a gap at the front
why are you positive your 40 is a 66? most were titled(look for brass tag on VIN plate) a year or so after they were made, so many 65's are 66's but are really 65's and so on
Sorry...I meant a fibreglass roof panel was for sale in CO at a really good price.
I agree with Pimp...double check your vin numbers...also check to see where yours places on the manufactured list.
Fj40L
fj40-35677
VIN from my 65 FJ40, its latter than yours and the brass tag means its titled at least one year latter than it actually is....
QUOTE=SHREG;3575736]Fj40L
fj40-35677[/QUOTE]
The frame has been painted. I dont have a brass tag. I will look for a frame number.
Thanks, now im really curious to see what year it is. Mine looks like Landpimps.... Same windshield and all.
Nice looking rig!
If it will help any, mine had a 4 in front for the FJ40xxxxx, but the vin shows it as being manufactured around Oct '63. Check the frame at the front right corner...you should be able to see the vin number.
I see that you have real bug catcher windows, so I'm guessing it won't be a '66. Where did you get, or what did you do for the seals for the bug catchers?
I myself am having a hard time finding the correct seals for the roof, so I may just buy some thick rubber sheets, and try cutting my own.
After your done with the top, you need to find some older style hubcaps, maybe paint your rims black...then your ride will be rocking!!
The picture below shows a vintage rim/tire/hubcap combo that someone posted up a while back...this is what your rig should have at all four corners to look stock.
Again...nice rig :beer:
The rig was nearly complete when i purchased it last spring. I need a seal for the p-side bug catcher... and All of the seals for the top.
I just had the rime blasted and powder coated. I love the way they turned out so i will just leave those.
Thanks! the PO gets 90% of the credit on this one.
I will look at the frame.
I checked the frame. There are no proceeding numbers or digits. the frame number matches the Vin.
Fj40-35677
The mystery continues.....
its NOT a mystery........just look at my 65's VIN #.....its just a bit higher than yours, so yours is a 1965....its really quite simple
a 65 would not start with 5, only thru 4=64, 3=64 etc.....but stoped in 1964, so your VIN makes since for a 1965
65 was the last year with the vent in the lower window frame. 66 did not have it
Fj40-35677
