This is an old problem and I've read about every thread on MUD. CRANK NUT
Here is the info..
-I have two 10/1985 FJ60 bodies and frame (one broken).
-One has a good 2f and complete drive train. This one is a rust bucket with busted frame.
-The other body and frame are rust free.
-I have moved most of the 2f and drive train from the rust bucket to the clean truck.
-I want to finish putting on the front end: radiator, fenders, front valence, etc.
-Before putting it completely back together I want to replace a leaky front seal. I have been trying to do this and put about 36+ hours into getting the crank nut off. Hasn't budged.
Problem
The engine turns with the breaker bar and can't get any leverage to turn the nut.
Can't do the bump method (start bump) cause the ignition is not in place yet and that move scares the crap out of me.
Here is what I have done:
-PBed the hell out of this thing. But with threads toward the back not getting much help.
-Heat the nut up with MAP gas for about 20 minutes (probably destroyed existing seal). I think a lot of the heat is dispersed -- never reached glow.
-light tap to moderate tap of the nut several times.
-Put a 1/2 inch electric impact wrench on it (worried now I may round the nut)
-I've tried sticking a large screwdriver into the flywheel teeth but I'm worried I'm going to break one off.
-Put it in gear and chauked the tires. Wants to roll over chaucks.
-Saw a video where a fella used rope and the frame to hold the pulleys. Rope stretches to the point of breaking. Now trying poly rope (the yellow stuff that floats -- read it stretches little)
-used a five foot breaker bar
-the truck keeps rolling and not getting any leverage on the bolt.
-if I could get leverage and apply enough torque I am hopeful it will go -- so far everything I have done has lead to turning the engine.
Here is what I am thinking
-Put a long heavy duty screwdriver in the front u bolt that will also run to the ground and prevent the drive train from turning -- question: do you think I would mess up the ujoint by doing this?
I have a one inch 46mm socket and thinking of renting a one inch impact wrench. What do you think.
Sure could use your help!
Here is the info..
Problem
