Newbie needs help. Trying to remove an old brake drum on a '71 FJ40 with out taking off the hub. The Toyota Repair Manual says to remove the drum set screws, tap the drum, and remove the drum. My drum wiggles slightly, but is no where close to coming off. The manual advises to back off the adjusting nuts if the drum cannot be removed. Where are the adjusting nuts? The only adjusting nuts I see in the manual are the ones on the cylinder, which cannot be accessed until the drum is off. Am I missing somthing? Or should I just take the whole hub assembly off? Suggestions welcome...
