OJ50 put in H55F
Alaska
I have a Brazilian OJ50 Bandeirante 1988 with what looks like a H41 and old style transfer case. I have a takeout H55F and new style TC from an about 84 Canadian BJ60 (fine spline trans input shaft). Anyone know for sure if it’s a bolt up to the bell housing? The engine is the OEM Mercedes OM314 but as mentioned the transmission is I think H41.
Gears are probably 3.70; I have BJ60 takeout 4.56 with Detroit rear ARB front and 34” 8.25R16s
Thanks
You know for sure the 4 speed transmission bolted to the Mercedes engine/bell housing has the same bolt pattern?
The H41 was made to fit both the B series engines and H/F series engines. Which input shaft your H41 has would make answering your question simple. If it has a B series input shaft yes. H/F series input shaft no.
10/85 the transmissions changed so doubt a 88 H41 input shaft would fit a 84 H55F. Otherwise may have been possible to switch the input shafts between the two.
The OM314 is neither a B or H series. I am very familiar with the difference between B, H and F series. But the Brazilian OM314 may be different. Anyone know for SURE?
I would say no since there are two different input shafts used on the H41 made to bolt to Toyota engines. If a third style was made to fit the Mercedes diesel engine I would have no way to know. Someone would need a Bandeirantes parts listings that used Toyota part numbers to compare to the listings easy to find.
