oil
And you know the 80 "likes it" by how ?? :)
Fred
With the thicker oil I have better oil pressure .The truck does not overheat while crawling in 100 degree temps through the desert. The valves do not rattle under strain in higher elevations and under a load. As i said my last toy sold running strong at 300K and i abused that poor car. 6cyl cresidda it would get rubber in 3 gears with 300K on the clock . I had a old ford truck same deal . The thicker iol seems to keep my junk running strong.
Like Beno said it is preference in the end. And where you live and how you drive. I also dump a can of LUCAS in both toys so cold starting is smoother more sticky oil every where inside the engine
The only real noticeable difference is it takes the engine longer to get hot with the heavier oil in there
I've found there to be positives and negatives for both the heavier oil and the lighter. I ran Royal Purple 5w30 for the first couple oil change intervals after purchasing my 80. Downsides were some oil consumption and timing chain rattle on startup. Switched to Rotella 15w40 at the last oil change, have had zero consumption since and no more rattle on startup, but I seem to have lost approx. 1 mpg and the truck feels a bit slower (subjectively, haven't done any real testing I suppose).
OZ LC Oil Visc. Chart
Now I don't want to here anymore 20w-50 threads saying "its to thick for the 1fz!!!"
It says at bottom of pic/page
* On engines with turbo chargers, never use above above 0 C (32 F)
That is on the Diesel chart for 5w-30.
Would that be the same for turbo or supercharged 1fz's?
How does synthetic oil fit in the chart? Can you run a thinner oil if its syn when its hot?
Also, why does the chart say 10w30 up to 100+ and 15w40 and 20w50 to 100+? How do you know if you need the
30, 40 or 50w if they all go to 100+?
Thanks Landtoy. So I guess the answer to Fred's question is "because Toyota says to".:)
They're several reasons:
- In the case of 5w-40 (who recommends that anyway these days ?) or 5w-30, it's because the 0w, as in 0w-30 or 0w-40 is hard to find. 5W-xx is easier to find.
- They assume that most people are going to use regular oil, not synthetic.
Fred
I'm pretty sure you're making this up. Even high-perf sportscars (and could care less about how easy it is to find) recommend 5w- or 10w.
0w is not hard to find.
My bet is they are simply trying to meet MPG goals. Try the thinnest oil possible for mpg's but still thick enough to lubricate properly.
If they did not have to meet those mpg goals, they would use thicker oil.
Also, I think it depends on how cold it gets in your region to what oil is best. If you get freezing temps, a lighter weight is better.
Our winters are about 50F so 'freezing' is not a concern
FWIW, I've been using Rotella 5W-40 for almost a year, even through the 0*F winter. My truck was happy.
:meh:
These oil threads always amuse me... Has everyone forgotten that these are Land Cruisers?
0w, 5w, 10w? I bet that no matter which of these you run, the truck will be fine for as long as most people will own the vehicle. You can quote all the studies, blah, blah, blah, the difference isnt enough to really worry about - there are still going to be trucks that run 300,000 miles on cheap crap and bad gas.
It all boils down to opinion, run what works for you.
Personally, I just started running Rotella synthetic 5w-40 (I think it was..... what ever they have at walmart ;-) ) after running Castroil 10w-40 in many cars for years with no problems (moved to Rotella so everything I own would use the same oil.)
I remember back when I worked at a dealership... it didn't matter what kind of car/ truck you brought in, if you were getting an oil change it got Quakerstate 10w-40 lol.
Around these parts everyone gets 10w-30, unless you specifically ask for something different.
Last time I got my oil changed (didn't have time to do it myself :frown: ) I asked for 5w-40. They had to dig out a box from the back that looked like it'd been sitting there for a while.
For my truck, seemed 10w-30 ran just fine in it, but the oil pressure gauge tended to drop more than I liked when idling or coasting (but was fine when under throttle or cruising). With 5w-40 it's nearly rock steady. :meh:
I have use it all from penzoil ,valvolin,castro syntec blend ,mobil one fully syntec and now I stay with rotella syntec 5w-40,run smoother and cheaper at walmart right oil for 4x4 better quality,try it to tell the differences.:lol:
