Am in the process of buying a '97. Drove it home and got it level and checked the oil. It was reading at the bottom line of the etched area. Let it set for about 1 minute and checked it again...same reading. Waited about 5 minutes and checked it again and it reads at the top of the fill markings on the etched side of the dipstick. However, the reading on the "slick" side of the dipstick was only up 1/2" from the bottom of the stick. Just barely even with the bottom of the okay on the etched side. What gives? Am I supposed to wait to check the oil? Why is the oil only reading good on the etched side?
The owner immediately changed the oil in my presence and put a Napa Gold filter and 7 qts of oil (owner's manual calls for 7.2 with filter change) and it only came to the exact same place as my reading after checking it within 1 minute of shut down.
A mechanic said I needed to wait for several minutes before checking the oil level on a straight 6. He said it takes a while for the oil to drain down back in to the oil pan.
