oil pressuse guage
Christchurch, New Zealand
after reading all the other posts about oil pressure, i think i ned to fix my guage up as when motor is cols i get a read just but once warmed up no reading at all. going to the garage sat so will get the pressure checked and then sort out were the problem is.
has anyone had a fualty guage,
jono
Oil Pressure
When you have done the tests witha proper guage post the results. I would be interested.
I took a mate out for a drive in my cruisre and he was quite surprised to see oil pressure on my guage. He has a 1991 JDM and the guage barely moves. Mine get up to the top of the middle segment when cold running and is always between the upper and lower segments all the time regardless of engine temperature.
Cheers
jono
It could be your oil pressure switch going bad. There could be a short along the wiring from the oil pressure switch to the instrument panel. Check your oil pressure with mechanical direct reading pressure gauge. Have fun and good luck.
IIRC post on here pointed out that the factory gauge is just there to show that there is some pressure in the motor at all. They said that the gauge is easly moved off of the correct position. Also that the way the gauge works is off of electrical resistance and not actual pressure.
There is a resistor with the oil pressure gauge, you would have to remove the intrument panel for access...
Installed an inline "T" for a mechanical pressure gauge which gives excellent oil pressure readings.
I stepped on that little wiring harness on the passenger side near the frame in the engine compartment. That tore the wire from the sending unit and killed my oil pressure gauge. I ended up soldering a new wire. You may want to check that wire.
mine used to show half at best when cold and none when at hot idel, changed the sending unit and whala. 3/4 cold idel and just below the 1/3 line at hot idel after a long drive.
Start there i think you would be suprized
Cheers boys for all the help. ran out of time on sat to get to the garage, will look at the wiring today, an possabliy take the das out and look for this resistor.
