oil pan gasket
any reason not to use that gasket in a tube stuff on the oil pan, instead of a pan gasket? my old man swears that he's only ever used the tube of goo, never bought a pan gasket in his life.
Same as my pops...no wonder my 327 does not leak at all. However, I have heard that the cork gaskets have better uniformity, and can absorb oil without allowing it to leak. Then again, I have always noticed everyone using the gasket with perma-tex.
On the pan, I have NEVER used a gasket. Always sealed it with perma-tex.
This help any?
Wait a second...I was the one to put the oil pan on the 327 in my Cruiser, while it was my pops. I used perma-tex, as stated before, and it still does not leak after 3.5years.
thanks, i'll let this be discussed for a couple of days before installing my pan. i'm eating 2minute noodles (i think you guys call them ramen noodles) for the next week because i blew my fortnight budget on parts (knuckle kit, intermediate shaft, wheel bearings, brake pads, oil change stuff, rear main seal). got plenty of permatex tho.
I would probably try 3M's The Right Stuff alone. I use it with the gasket. The only problem is that those oil pans are generally warped in the removal process, and they are built to fit those curved ends with a 4mm gasket in place, and I could see you maybe not getting all of the gaps filled completely if you used it without the gasket.
i used the rubber gasket ccot sells and NO permatex or other goop. so far no leaks but i am concerned that i should have put something on there for safekeeping. am i to expect oil pan gasket maintenance in the near future????
Dont cheap out, go with a Toyota gasket, you will never lay a bead correct enough on the front and rear of the pan to seal properly, and every time you are on any kind of incline the oil will run out.:cool:
How long ago did you do this? I am guesssing no maintenance until you taco your oil pan on a rock...
Felpro SnapUps make oil pan gasket installs a cinch. I describe them in a tech section write up for oil pan installs. Sorry, no pics. Toyota gasket is the best way to go.
1. Is it possible to drop the oil pan and put on a new gasket without loosening the motor mounts and raising the engine in order to clear the oil pump? (1978 FJ)
2. The Haynes manual says to put some sealer material on a few spots on the gasket before installing it. If I am using an O.E.M. cork gasket, do I still need to bother with a few spots of Permatex?
Thanks.
Thanks.
1. Absolutely. Not required. We are talking about an FJ40, correct?
2. Yes. toyota FIPG works best. One dab or so in each indicated corner. That's because the gasket doesn't seal that sharp angle without the dabs.
