I was once told that any question ever asked about Land Cruisers has already been answered on Mud. So briefly looking around, I tried to find if there was any reason to try to coat the inside and outside of my pan with something specific (as of yet unknown) after welding in a new plug. So is that really cool coating something special? Should I try to coat the area of the weld with something? The thing will be in an oil bath the rest of its life with any luck. And if anyone has dropped the pan in an 80, what is that seal over the plug that seems to have a rubber gasket on the inside of the pan? I decided to go way up to a 3/8" pipe plug and thought I would just drill that thing out but it was still there after drilling out. I pried on it for a second but any more and I would have deformed the hole so I just welded it up on the outside. Surprised it didn't affect my weld but everything went well.
I would just paint the outside and call it a day to keep the rust away. I haven't seen the inside of an 80 pan but I have seen inside plenty of Toyota pans and as far as I know theres no seal between the pan and the threaded insert for the plug, its just welded into the pan from the inside. but then again I haven't tried to pry out the old threaded insert
I've had my pan off but don't remember anything special inside, just paint and a threaded hole. I would just make sure to get any loose, blistered paint out of there from welding and not really worry about painting the inside since it is holding oil. Do paint the outside. Any decent rattle can should do.
I think you're right. Not too worried about it. But that paint seems so incredible and smooth I just wanted to make sure there wasn't something about it I didn't know. I am trying to upload a photo of the grommet/insert just for posterity. Maybe it will upload some day
