oil line protection
Virginia
I have headers on my 71FJ40...I just replace some old, rotted oil lines with the neoprene ones from MAF. I could have gotten the steel braided ones, but didn't. Then, I thought of something.....
Could I just wrap some heavy duty aluminum foil around these neoprene lines where they sit behind the headers (between the block and headers) where they are most vulnerable to heat? My thought is that this would protect them from getting burned.
What do y'all think?
Doug
ShaneD said:
an old piece of heater/rad hose
I have this setup on several crucial lines (fuel, oil) that run near hot or abrasive parts. works awesome as both heat and abrasion buffer. cheap and solid solution as I have lots of used line types and sizes sitting around - or can just go buy in bulk from Napa.
just to be clear, I use the old radi/heater hose with OUT the tin foil and metal tape with no problems. that hose is rated plenty enough to take the heat and it is firm enough it wraps around the smaller hose diameters and stays just fine.
