oil leak
College Station, Texas
Hey guys, I'm new to the forum so forgive me if this info has been posted before. I have a '77 FJ40 with the 2F engine that has an oil leak. I thought it was coming from the rear main seal. I took the bellhousing cover off today and sprayed the back of the flywheel and around the oil pan area with brake cleaner so I could see the leak and verify the rear main seal leaking. I started the engine and didn't see any oil leak from around the seal area. What I did see was oil leaking between the back of the engine and the bellhousing. It's on the left side higher than the rear main seal so I figure its not leaking. Does anyone know where the oil may be coming from? Is there a plate and gasket on the back of the engine where the cam bore is? Its leaking pretty good now where as before it was a little drip and more of a nuisance than anything. I can't drive it now because the leak has gotten so bad today. Can someone shed some light on what I need to fix? Thanks, Matt.
Could be coming from your rocker arm cover/gasket leak.
Frost plug on on the end of the block where the rear cam bearing is located...
Could be your issue.
Would need to remove the flywheel housing to verify IIRC...
Good luck!
Oh, and welcome!
-Steve
I'm thinking it's the plug. I checked between the engine and firewall and it shows no sign of oil leaking. I wish it was as simple as a valve cover gasket, but I don't think I'll be that lucky! Thanks for the help and the warm welcome. Matt
One more thing. If it is the plug, is it available at the parts store or will I need to order one from a specialty parts house? Matt
Sounds like the cam bore plug (what was called a frost plug above). It is square shouldered and shallow. I haven't ever fouind it sold individually in the parts houses. I may have found a frost plug that worked there, or maybe not. I can't remember. If I did, I may have had to carefully grind it to fit.
Best to order one from the dealer.
It is unusual for this to leak. When you get in there, look to see if it has been pushed slightly out of the hole by the cam. If it has, you *may* nee to take a look at the front of the engine where the thrust plate is supposed to prevent the cam from shifting rearward.
oil leak update
Hey Guys, here's an update on my oil leak problem. I spoke with Robert at man-a-fre in California last week. He all but convinced me that since the oil leak appeared to be coming from the left side of the engine, that it is probably coming from the oil galley plug between the bellhousing and the block.
I pulled the motor out last weekend and sure enough, it was the oil galley plug. I had ordered the plug as well as the cam bore plug from man-a-fre, but of course, it haden't arrived by the time I had the motor out (ordered the plug on Tuesday still haven't seen the parts). Anyway, I ran all over town and managed to find a 25mm cup type plug (the proper size is a 24mm disk type) at the parts house. I flattened the back of the cup a little and managed to get the plug to stay in the hole. Naturally it was a cup type and was sticking out past the back of the block. I filed it down almost flush. I left a slight bit sticking out. I figured since the bellhousing bolts up on top of the plug, I would be okay.
Well to my surprise it worked!! No more oil leak. I can't gaurantee that it will not leak but, I don't see how it can. The guy at man-a-fre said that most engine rebuilders (this one was rebuilt about 500 miles ago) don't have metric plugs in their shop so they use an SAE plug and most of the time they leak.
I was really skeptical about the plug not leaking but I was in a bind and didn't want the motor hanging in my garage for 3 or 4 days. Maybe if it does start leaking, I'll have the parts by then!!! Matt
you should try to find out who rebuilt the motor and ask them where they got the new freeze plugs? the plugs from some kits suck, they dont have they same dimple as the ones from a toyota dealer. the ones from the kits blow out and leave you stranded on the road or trail... i m currently working on the front oil plug near the timing cover. ive had to replace all the freeze plugs for the water and now i have to do the same for the oil. so find that mechanic and check his sources. sounds like you got that leak taken care of. good work matt
Yea, I planned on doing that eventually. The motor was rebuilt like 2 years ago. The cruiser had been sitting awhile when I bought it. I doubt the shop would even have a record of it. The parts guy at man-a-fre told me that a cam plug will leak off the passenger side of the bellhousing and the oil galley plug will leak off the left side. Seems like he knows what he is talking about. I bought 2 of each from him just in case. I kinda wish I would have waited for the right plug but you know how it is when your in a bind! Matt
i only get my plugs from toyota becasue i have had bad luck with aftermarket plugs poping out. its will only be like $3.00 toyota
just a thought
I've always heard that if a Cruiser aint bleeding a little then it aint runnin' right! Welcome to the addiction!
Later
Sorry for jumping in late, but leaking cam plugs seem to be a comon problem. They tend to leak down the back side of the block and drip off the passenger side main cap bolt. Rear main seals tend to sling oil off the front side of the flywheel and make a mess inside the bellhousing. In the two leaks I have seen it was cam plug 2, main seal 0.
I wanted to tap it too. I didn't really know what I was dealing with until I had the motoer out. Then I couldn't find my pipe tap and didn't want to delay. Believe me, if it leaks again I'll do something a little more permanent. Matt
