drain , refill , drive
you dont think one of his axle seals is bad? mixing oil and knuckle grease?
I agree with the above, but check it in 500 miles. I would not be in a hurry to tear the entire front end apart.
Who did the birf job? Did they over fill the cavity? Did they lube up the shaft when they reinstalled the axle? Did they replace the inner axle seals?
How bad is the soup? Just dirty, real dirty, or chunky? Mmmm
He did the birf job. He said he replaced everything (bought the stuff from dan)
Id say it real dirty but not quite chunky.
Also, has he done the diff breather mod? I think 100% of owners should. This factory snorkel tip needs to be removed. It easily plugs and becomes a one way valve casing a vacuum in the diff each time you shut down - pulling grease into the diff.
After a rebuild, there's often been a lot of grease build up in the diff and loooong axle housing. So, common to see this soup come out the diff. So, refill and drive as noted above. Check again in 1000 miles and you'll probably still have the same stuff from this previous build up. Takes a few cycles before your front fluid will come out clean.
DougM
