Oil for Transfer Case
Greeley, CO
Website
www.suite121.com
Hey all,
I'm new to these forums but really like what I see. My buddy a Cruiser fanatic so I decided to see what all the hype is about. I bought a 91 Land Cruiser and have to say I'm very impressed.
Here's my issue the truck has 240,000 miles on it, the transfer case chain has stretched and pops when you let off the accelerator. It's pretty minor but something I would like to fix.
My mechanic quoted my $1500 I only have $3000 into the truck so that seems a little steep.
I was told about Redlines anti-shock oil and that it might help eliminate some of the poping. Here is link to the product.
http://www.redlineoil.com/product.aspx?pid=42&pcid=8
Any thoughts or ideas.
Also, is there anything else I need to fix or checkout right away - routine stuff.
Probably buy a used tcase for a couple hundred in the classifieds - parting out section
Red Line is good stuff, don't know if it would help your issue
You know the t-case in Land Cruisers does not have a chain, right?
If your mechanic says the chain has stretched, you need another mechanic.
The t-case rarely goes bad, and when it does, it's the bearings and they make a growling or deep whining noise.
Do not buy a new t-case untill you know this one is bad. I would pull the drain plug and see if it has a lot of metal shavings on the magnet.
Just making a wild guess-if your noise is worse on decelleration-you rear differential pinion bearings are likely worn out. That's normal at your mileage.
Thanks for the input. I think it is time to find a new mechanic. Does anybody know of one in Northern Colorado?
Romer - Thanks for the link FAQ those really helped. I think I'm going to change and flush out the oil in the differentials and Transfer case. I'm going to use the Redline products. I will let you know the outcome. For the transfer case should I stick with the recommended 75W90?
