Oil Filter Survey...
Victorihhhhhaaa
Curious as to what filters everyone here is using, I am aware of the Oil filter study but it leaves a bit of leeway as to what would be the best way to go...
Im thinking of switching over to AMSOIL filters (either their EA or WIX) and their 5W-40 full synthetic... ideas? opinions?
Toyota
Toyota.
NAPA did not have the oil filters for my HJ60 and could not get them.
Baldwin.
Toyota OEM for my 1HD-T, Crappy Tire for the old 3B. Both excellent value for the money.
For my old 3B I took apart an old Motomaster once and compared it to an OEM Toyota that was selling for three times the price... NO DIFFERENCE, looked like it was made at the exact same factory. I suggest you do the same and draw your own conclusions.
For the 1HD-T, the OEM is one of the only filters to have dual elements, one for coarse stuff and one for soot. I buy them by the case at a great discount from Canadian prices (3 for the price of one in Canada) at the Toyota dealer in the US.
i use wix. spoke to a guy (very knowledgeable with diesels and rebuilds them) who opened up a toyota, wix, purolator, and fram filter and he said the oem was still superior, followed by wix/purolator...fram was c-rap, had way less filter coverage....
hmm, maybe i'll try motomaster if i can find the right size...maybe the same guys that do wix does 'em too.
Remember no-name brands such as motomaster may switch manufacturers from time to time. A tiger saw was all I needed to cut the filters open when I made my test, and I didn't even waste the filters, did it when they were spent. A bit messy but worth it :)
My 13B-T uses Purolator Pure1 #PL30001; top rated by most oil filter studies.
Avoid CdnTire filters, they're made by Fram, as are a lot of other 'name brand' filters like Quaker State, Penzoil, etc. Fram is about the worst filter one can buy. You can easily tell Fram-clones by comparing with Fram filters.
Fleetguard is a Cummins product isn't it? Anyone have the part numbers for the 13B-T? are longer filters available with the same threading? (IE more surface area)
Edit:
Ok never mind Fleetguard equivalent of A (NGF 1515MP/PH8A) is a: LF3487 (for the fancy synthetic version...) ill look into a larger unit that still fits...
Well whatever you found by survey I can assure you that at the time I took my Crappy Tire 3B engine filter in 1998, it was IDENTICAL to the the Toyota OEM filter for that same engine. IDENTICAL, except for the paint on the outside of the can!
Do your own testing, take apart your filters and find out for yourself. It's cheap and easy to do, albeit a bit messy.
