Good to know. I have a vice. How long would it typically take to do something like this, assuming I am a
mechanic and I have all the tools needed?
EDIT: Since the FSM recommended Dextron type II fluid isn't available anymore (at least near me), Mr. T recommends type IV instead.
I'm doing this as soon as my parts come in; there were no locally available kits, so I have OEM coming.
In my case, two hours to remove everything:
a) battery and tray
b) alternator, w/ adjuster and mtg brkt
[move the alternator drive belts to the A/C side of the engine, otherwise they'll get covered in PS fluid]
c) ps pump and reservoir [I used a mortar tub to catch the fluid, works really well and has many other uses]
d) change oil, remove filter, because it's in the way of the fuel filter, which I can almost reach now
e) fuel filter, because I can reach it now
an hour to clean everything, including the block
an hour to rebuild the pump
an hour to reinstall everything, which goes together easily now that everything is clean and oiled (now's the time to replace those belts
an hour to bleed the PS system; remember you have to have the front end up on jackstands (also, use PS fluid, not ATF; the ATF mentioned in the owner's manual is for convenience)
You DO NOT have to remove everything I've listed. You can fight with everything in the way, curse your skinned knuckles and then take everything apart when you break the nut loose under the union bolt on the pump. There's no way you can hold that nut and break the union bolt loose with everything on top of the pump. BTW, the union bolt is 22-mm and the nut is 24-mm. I used a 6-inch crescent wrench to hold the nut (it wedges itself against the frame), and an 8-inch crescent wrench to break the bolt loose, after I smacked it several times in the head with a brass drift. You may also need PB blaster, liberally applied beforehand.
If you round off the heads of the nuts holding the pump on the timing cover, they are the same as the EGR nuts.
Also, if you want clean, new fluid in the system, you have to remove the paperclip cooler to drain it.
Parts list (these are what I needed, YMMV):
Also, the long hose to the bent tube on the side of the reservoir is not available form Toyota separately (AFAIK), it's part of the paperclip, which is ridiculous. Both my reservoir hoses crumbled, literally, when I removed them. I suspect the other hoses in the system as in the same shape, but I'm ignoring them, for the time being.
HTH
