oil cooler
Fairbanks, AK
Hey,
I was looking at the water pump the PO had put on my '78 Fj40, and noticed it had the output for an oil cooler but it was capped off. There is no oil cooler on my rig. Did 78 40s have oil coolers and the PO may have removed it? Or do you think he got a water pump for a later model. (I know my '85 fj60 had an oil cooler). Just curious, I don't work it hard enough that I am concerned about needing an oil cooler (especially here in Alaska).
Thanks!
If it does not have a similar "capped off" port on the T-stat housing, he just got the wrong pump and AFAIK, there is no problem with leaving it that way.
OTOH, if you want/need a cooler, I have a nice one.:D
Ed
Ed,
You're right, there is no spare plugged port on the T-stat housing. So I would assume that there never was as oil cooler. Does anyone know if 40s ever had an oil cooler? If so, what years?
Thanks
Matt
I think they were an option on cruisers from about 76 on. But they can be put on any F with the oil filter on the passenger side or any 2F. They work with either direct drive or clutch-fan water pumps.
Ed
I don't think my '77 has one but with all the oil 2F engines hold, I don't think that it's really an issue.
